I have the following items for sale. Prices has been reduced cause i need this gone to free up space.
1) Full set of wheels and tyres. 19x8.5 +38 offset, 4 x 114.3 stud pattern with brand new tyres. (only ever used to clear defects) $500
2) Rb26 2.5" split Dumps to 3" Front Pipes. bolt on upgrade for R32/R33 GTR. these were on my car when it made 361kw at wheels. Took off to upgrade $220 bucks.
3) RB26 Stock Blow off Valves. Good working order. $60
4) SR20DET T2 Steampipe Manifold, looks a bit rusty BUT will never crack like these chinese ones. Direct Bolt in Replacement. $70
5) SR20DET dump Pipe with screamer, screamer has some burn marks on the bottom from where it was spitting flames. $40
6) RB26 Twin Turbo Top Pipe $20
7) RB26 Hot Pipes to intercooler, $20
All items located Newcastle 2302, Pickup available during business hours only from my work. Can post smaller things at buyers expense. will not post wheels.
Pics below.
https://www.sau.com.au/forums/topic/440303-various-rb-and-sr-parts/
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
