So I just finished putting a rb25 gearbox in my r32
Got the custom tailshaft to suite
But basically, I can put the car into all gears, while the car is on, and my revs don't change, it doesn't stall, it doesn't move at all. But I need to use the clutch to put it into gear
It moves ever so slightly then just nothing
My mate said my tail shaft is too short, but it splines onto the gearbox which I can easily tell, and I ran the car on jack stands with no tailshaft in, and the spline on the back of the gearbox spins
Does any one have any ideas :/
Have to use the clutch to put it in gear, thats not unusual?
cant you put the back of the car on standsso the wheels are in the air and then (carefully) put it in gear and have a look. Obviously if the tailshaft doesnt spin at all then it isn't engaging the shaft out of the gearbox. If you want to confirm this, you could use some spacers and longer bolts on the diff flange for the tailshaft so that the front will go further in the gearbox. Again be careful doing this, while on stands, and be gentle putting it into gear.
It's just something to check it, dont go driving around like that because its not good at all
And yeah haha I actually wrote in my first post I did that,
Thinking it may now be the slave cylinder, the pin is seized and isn't fully de compressing, leaving the thrust bearing pushing on the clutch still when the clutch pedal is disengaged
Being like that the clutch slips, so it grabs slightly but very weakly, which is my problem
If its a 25 box and the slave is stuffed, it means you wont get as much clutch disengagement rather then engagement. So you should have the opposite problem, hard to get into gears, but has full clutch contact when the clutch pedal is released. To confirm this you could just remove the slave and leave it hang. Then start the car in first with the wheels in the air and they should spin happily. Otherwise if its an issue with how much clutch slip it has (more then normal) then you could try the same thing but then try and start the car in first with it on the ground. make sure you have plenty of room obviously, because if it does start and the clutch is engaged it will move forward until you hit the brakes or turn it off.
what was the condition of the clutch that went in it? Was the gearbox known to be working before it went in the car? From memory the output shaft will spin a little bit with the car in neutral with no load on it
The clutch might have an issue
Clutch was good I've been driving with it for a year
Box came out a car I wrecked
If the slave pin isn't releasing all the way then it'll give me the issue what I'm having
That's a good idea about taking the slave of and driving it in first (or reverse for me as its in the shed..)
100% not a clutch issue (as in pressure plate clutch plate flywheel etc)
Definitely not a diff issue
One thing I noticed, when my rb20 was out, I could attach the box then the slave after,
With the rb25 gearbox on, I can't attach the slave cylinder after as its too stiff, which makes me believe it hasn't retracted all the way
So I believe th slave is stuffed
If that makes sense
Yeah might have a siezed or damaged slave. I got mine honed and re-sealed from a brake shop for $50. Looked and felt like a brand new one. They can re-sleeve it if the bore is to wrecked. Give that a go, sounds like it needs a rebuild anyway
Cheers for your help man I appreciate it
Took the slave out and wheels spun in gear as they should, fiddled with the slave and got it to retract properly and threw it back in, and car drove right for a minute before the slave got stuck again
Ordering a new slave today
May aswell just get a new one I suppose
I couldnt' source one locally and after having my car off the road for 3 months, and not wanting to wait over the weekend for parts, I thought it was better to just get it re-kitted. Only took them about an hour as well.
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
