How could adjusting suspension have anything to do with it?
Do you think you can undo 4 bolts and unclipped the wiring going to the buckle?
If you can,pull it out and sort it out.
I assume you can't though and that's why you made this thread ;)
Came here to help unlike these trolls.
Check the cam valve because I had this same issue last time I changed my suspension.
If you are looking at your turbo it's underneath and runs to the block. (unscrew it slightly until you see a little oil leak out)
Helps with the vibration through the rails which causes the squeaking seat.
  • Like 1
Thanking you!
Thanking you!
Hey Anna,
My outbox on my SAU account is full so I'll just reply in this thread for you.
The cam valve will be the thing causing the seat to squeaking when you lean to the left.
If you have the same issue when leaning to the right as well then it will be something much more sinister.
Try get a few pics of your engine bay around near your turbo and I will circle the spot you need to adjust.
Cheers,
DK
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
