I am not wanting to go wild with my R32 GTR but do want to increase boost to a safe level. It has the standard ceramic wheeled turbos. I am hearing many varying opinions on safe boost level with some people saying up to 18psi.
I am wanting to know at what boost any people have experienced failures. For example, if nobody has had a failure at 14psi then I am happy to boost to that level but if ANYONE has had a failure at that boost then I won't go there (just to be safe).
Hopefully we can come up with a level that will allow me to sleep at night.
https://www.sau.com.au/forums/topic/44036-gtr-boost-experiences/
This argument is always debated, however as far as I know.. the limit of the stock ceramic turbos is around 14-15psi... you can safely achieve this by removing the restrictor. Other have run much more, but the argument is not IF but when will your ceramic turbos give in, and risk further damage to the motor by debrit.
my turbos have been running ~1bar (14-15psi) for over 20,000kms, no problems...
Best to get a tuner to do it, make sure the A/F ratios are safe etc...
i think jezzr (he posted about running an 11 on stock turbos) is running 18psi
Also depends how your driving, I don't think 1bar on stock turbos would last long on the track (correct me if i'm wrong?)
Daily driving 1bar should be fine
Bad news Ken! This was on your R32 I assume and only at 1bar. I vaguely remember you telling me at your shop only a couple of days ago how there is definitely no problems at 1 bar, just kidding!
Incidently, you know how you had my GTR on the Dyno and it ran up to 8200(rev limit???) and slight boost increase to 10psi which lead you to believe it had computer work done. Well it would seem that you were right. I pulled the computer side kick panel off and it has a Mines tuned computer with their serial numbered gold guarantee sticker on it with tamper seals that haven't been broken. It would be very interesting to see exactly what has been done to the car. I would have thought it a bit strange to have it Mines programmed when as far as I know there is only a 3inch exhaust on it and only producing 263rwhp.
By the way if any of you guys are in Perth, Ken did a pre-purchase inspection on my GTR and he is a great bloke to deal with and the inspection was very well priced too. He really knows his GTR stuff (except the safe boost level on std turbos )
I've got a 32gtr engine in my gtst and I was wondering if its worth buying a factory boost controller and hooking it up. How well do they hold boost, do they spike? I know an aftermarket one would probably be better but are they worth the extra money on a stock motor? I am a tight ass!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
