Hey guys,
I was driving tonight and noticed that the dash light on my R33 started flicking on/off for a few minutes then eventually died out completely. I have checked the fuse and all seems to be intact no sign of blown fuse (which one controls the dash light anyway?) so am thinking it's the globes?
I changed my dash globe nearly 3 years ago to aftermarket blight blue ones so it wouldn't surprise me if it's finally blown but here's the thing - my stand-alone boost gauge (I did not wire it up) is connected to my headlights so when it is turned on my dash lights / boost gauage also lights up but both are out now so is it fuse or globes?
If fuse, any suggestions and can you please pinpoint exact one needs replacing?
Cheers
https://www.sau.com.au/forums/topic/440391-dash-light-out-fuse-or-globe/
Hey guys,
Cheers
If 1 light went out, it's not the fuse. If they all go out, it's the fuse. Highly unlikely though, because your headlights and tail lights will likely go out as well as generally they are on the same circuit.
If the aftermarket bulbs you have put in are LED, the chances of them blowing are minimal, but what I found is that they are not a perfect fit most of the time, as they may work for a duration, they eventually bend the contacts back and wriggle out. Take out your dash, locate the 'blown' globe and pull out the housing with the tabs on it. Using a small screw driver pry the tabs closer to the centre where they would contact the globe, put the globe back in and see if it works now. Maybe remove another globe to see if they works in the same position. If it does work, then it's the globe, if not, the globe either a) isn't making contact with the circuit board properly or b) the more unlikely option is the board is f**ked.
Now go forth and FIX!
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
