Hey guys
I have had an issue with a small knock at the front of my car. I have tein coil overs that are fine.
I also just replaced the sway bar links as they seemed to be the problem.
But it seems as if it's still there.
One thing I just noticed while sitting in the garage till 12 at night trying to get my head around this. Is that the from axles for the 4wd system seem to have a bit of play in them back and forth as I move them towards the motor.. Bit of a mood question but is that normal???
https://www.sau.com.au/forums/topic/440392-rs4-c34-front-axle-help/
A common place for a knocking noise is the top mount of the shock. Did you reuse the factory mount or did the shocks come with new top mounts (either bush or pillowball/rose joint). Also is the shock top nut tight?
Yeah it's doing my head in...
I have new sway bar links. Sway bar rubbers etc. it only doe it on certain bumps on the road someone suggested lower control arm. Is there a way of testing these??
Just jacked car up at work the lower control arms seem fine. No movement or leaks. The strut brace nut was a lol loose and it had movement in it. Went for a drive and seems ok but will know for sure tonight. But I hit another f**ken pot hole this morning and now the front left has a knock when I turn :( can't winpost-107907-13945993395038_thumb.jpg
you can overtighten them like any nuts but they are much more likely to be under tight :) If you aren't confident in how tight they should be either get a mechanic to do a quick check (should be free) or use a torque wrench to make sure you don't go too far.
Hopefully whatever the new knock is can be found....but maybe stay out of potholes? :P
