This is purely an expression of interest but if I get a solid offer I will sell so please give me your thoughts.
1992 Nissan Skyline R32 GTSt
Engine and Drive train
RB20DET 200rwkw 0n 1.1BAR (16psi) serviced with OWS synthetic every 2000kms
The turbo is a sereia compressor wheel and T3 exhaust wheel in standard housings.
GTR Intercooler
Z32 AFM
Custom ECU
Air Pod
400hp Bosh fuel pump
New Exedy custom 5 puk button clutch
Thermo fan
3 inch exhaust from dump pipe back (no cat)
Locked diff
Suspension
Buddy club height adjustable front
Tein HR height adjustable rear
Strut braces front and rear
Adjustable camber bushes front
Adjustable castor rods front
Fully adjustable rear control arms and trailing arms
HICAS lock bar
Kazzama sub frame locking kit
6 Point roll cage
Interior
Momo wheel
Momo shifta
Recaro bucket seat
6 point harness
Boost gauge
Exterior
Bright Red
Genuine R32 GTR N1 plastic front bar
Carbon fibre GTR Bonnet
Stickers
Gaffa tape
RHR quater panel needs repair
Rear bar needs re paint and fit
Front bar needs repair and fit
17 inch trial tri spoke wheels
$20000neg
https://www.sau.com.au/forums/topic/44040-r32-gtst-drifta/
  • 11 months later...
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
