When talking an engine like yours the term "mob i might try" should never be spoken
Go to someone that knows what he is doing and has a good reputation for this type of work
if I was you I would contact DVSJez and see if he can run it up and tell you what is going wrong
  • Like 1
I have his number and to be honest I am farking sick of this shit.
If they tune rich all the time it will be the same again if I give it back to them
I will call him tomorrow
It is quite possible they haven't set the dead times for the ID1300s correctly
But then there is a heap of things that could not be set exactly correct that need to be which is why you need to take it to someone that knows what they are doing and not just the local mechanic
I do not understand, these blokes have been doing this for a long time and have people out there that swear by there work. You would think this would be easy for them to do right in the first place :/
I will not bore you blokes anymore and thanks for your suggestions :)
  • 3 weeks later...
rockauto is where i got my ls coils
Where do you guys buy your AC Delco D585? Seems like this place has a pretty good deal, http://www.amazon.com/ACDelco-D585-Original-Equipment-Ignition/dp/B000BYD3Y0
http://www.ls2rb.com/buy.html
Goto that link for the supplier who makes them custom coil pack mounting brackets.
Yeah thanks mate
Josh PMed me the link aswell, I'm just making sure i can get everything i need then i will order one or two, so most likely this week
  • Like 1
  • 1 month later...
  • 4 weeks later...
Hi Guys,
Looking at doing this conversion on my SR.. I have found plenty of wiring diagrams so Im pretty sure I can sort it out. BUT if there is a plug and play harness already made by someone I'd be pretty keen to get one.
Also just let me double check, the coils I should be looking to get are D514A? I can get 4 acdelco ones on a bracket etc from ebay for around the $160 mark including plug cables delivered to AUS
As for dwell it seems I should be chasing around the 4ms mark at idle to 3ms top end?
I am running nistune and e85
Edited by RSI497
To summarise the way I understand it;
- D514A are powerful and safe, D585s are powerful (guessing probably more than D514A) but can fire early if you run too much dwell, that is, over 4 ms. Firing early "can lead to major engine damage".
- Genuine coils (AC Delco or Delphi) are more powerful than generics.
I'd guess you'd want maximum dwell at maximum torque, because that's when its going to be hardest to ignite the mixture.
  • Like 1
  • 3 months later...
Has anyone on here swapped to the LS2 coils while using a Power FC?
I'm considering the swap and given the difficulty with changing the Power FC dwell settings, am wondering if the D514A coils will work fine on the stock Power FC dwell settings?
