I have heard about Yaris coils, Scott @ Insight actually mentioned them at the same time as the R8 ones and they are a consideration but I'm leaning towards the R8 coils because NGK do a replacement and they have a shop at Homebush
I see more and more people using R8 Coils in RB26 . But I still have yet to see some test against each other in spark power.
I have seen a vid of a guy that tested the R8 coils and they made 45kv, not sure how that compares but it sounds like alot :)
I have googled heaps and yet to find anyone actually using them on a 26 :/
But then I googled heaps about the LS2 truck coils and didn't find any bad posts till after I lost an engine :(
thats not really saying anything compared to the ls1 coils that had a comprehensive test.
  • 3 months later...
May be it is a Canadian thing quite a few members on http://forums.gtrcanada.com/ uses them, and they purchase their wiring kit from https://www.facebook.com/simonpierre.foucault
The 300ZX guys are using them too http://www.aus300zx.com/forum/showthread.php?t=332677
Edited by etang789
Heres my LS2 coils sitting in a NEO head. Simple brackets, parts of the webbing across the head had to be drilled down. Doesn't have to look amazing because the cover fit's over the top! :thumbsup:
Wiring Specialties in the USA do a plug in harness for LS2 coils to suit different model skylines for around $150, mad not to use one!
found another variation of the VAG Coils done by Ignition Projects , its basically Porsche Cayenne Turbo coils . Don't know how these Cayenne Turbo Coils vs R8 Coils vs LS2 Coils in firing power. It would be nice if someone can do some extensive testing on these. Seems like the biggest advantage using the LS2 Coils is sits much lower than the VAG Coils.
More info on the Cayenne Turbo Coil over plug setup here, http://www.speedhunters.com/2014/10/a-spark-of-efficiency-project-gtr/
Edited by etang789
  • 3 months later...
Some Quite Interesting, but unverified, tidbits;
This ebay add says;
Nissan OEM coil : 22 KV
Split fire Coil: 24KV
LS1 Coil : 30Kv
LS2 Coil : 34Kv
LS2 TRUCK (with alloy heat sink): 42kv, twice the firing power, GUARANTEE NO MISS FIRE 32PSI (2.2 BAR) @ 1.1MM GAP
And this post on performanceforums says;
so coil energy at max safe dwell before saturation begins is:
Yaris @ 2ms/6A 78mj
Toyota @ 3ms/6A 117mj
D585 @ 8 amp dwell (UNSAFE) 256mj
D585 @ 6 amp dwell (SAFE-ISH) 144mj
I just got the aem smart coils for my rb. They have been well proven to stupid high power and boost. Nearest thing to cdi ignition without needing a cdi unit. And for around £50 a coil you can't complain :)
http://cloud.tapatalk.com/s/585aeba725647/20161028_170501.jpg?
So we trialled my LS2 Truck Coils. Setup is stock coil boots and springs onto the end of the LS2 truck coils. Misfired at 17psi with a 1.1mm spark plug gap, put 0.8's in and it fixed it.
Need to spend some time looking into it, maybe needs a direct power feed, maybe needs better boots and MSD coil springs of some sort.
How did you set the dwell? Or did you leave it stock?
FWIW the coil power feed on the RB26 appears to be a dedicated, relay driven circuit. I'm hoping its ok to re-use when i do mine.
Found the equation to change it into crank degrees for the PFC. I changed them all to suit 3.5ms at each RPM interval. Wasn't good enough and even 4ms was still causing a misfire coming onto boost.
Have you got a good earth/ground?
Yep, and check that you have the full ~14.5V (alternator charging) at the coils when you're hitting boost. IIRC another SAU'er had an alternator who's output was trailing off higher in the RPM band, so you'll want to log it, even if only at the ECU (cause logging at the coils probably wont be so easy).
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
