On 12/30/2016 at 6:39 AM, WMDC35 said:
Have you got a good earth/ground?
It's currently earthed to the fuel rail, not the chassis body.
On 12/30/2016 at 3:47 PM, MrStabby said:
Yep, and check that you have the full ~14.5V (alternator charging) at the coils when you're hitting boost. IIRC another SAU'er had an alternator who's output was trailing off higher in the RPM band, so you'll want to log it, even if only at the ECU (cause logging at the coils probably wont be so easy).
I will need to check it properly. Before the engine went back in, I had an auto elec test the alternator and he said it was working as it should (no other details though).
On 9/22/2014 at 0:56 PM, BlueRB240 said:
I'm thinking about cutting up some copper tube and shaping the ends instead of using these - would it be ok?
So alternator is rock solid. Added an extra 10% dwell through the rev range, has helped a lot, one tiny hiccup coming onto boost and then no problem after that. I do believe the factory springs and boots are the issue though. What else has everyone done to mount the LS2 coil packs directly onto the spark plug? I saw someone tried these terminals but not sure how they crimp onto the end of the coil pack.
New-set-of-10-MSD-34605-dual-band-spark-plug-terminals
AFAIK: The rolled up end will be for connecting to the plug, so about 6.3mm ID. For the other end, crimp it down enough so it grips on the coil terminal a bit. If your coilpacks are D514a's or similar, then the connector will be "captured" by the plug and the coil terminal when its assembled, so wont be able to move.
If the boots are problem (insulation problem), then there will be arcing from the coilpack to the head. Sometimes putting a little dielectric grease the surfaces where the boot touches the coilpack and head can help with that. If the boots ripped you'll have to get another.
Yep exactly what I was thinking cheers, just yet to see the connectors in person and make a fair judgement. I'm using the LS2 coil packs, although they are the BS1251 part number, which one person in this thread has said they're the inferior made genuine ones. I upped the dwell by about 10% and that has made about 90% of the misfire go away for now, with maybe one hiccup as it hits boost. More investigation required!
EDIT: The 6 pin plug is 1 -> 6, not 6 -> 1. Working now
Ok i've got mine installed and wiring in, but no worky. Here's how 6, 5, 4 coilpacks are wired - does it look correct? The 3 and 6 pin connectors show facing the factory plugs, and the others are facing the coils.
AFAIK the +12V comes up when IGN is on, and the signal from the ECU is +5V when the ignitor should disconnect ground to the primary solenoid, right?
  • 1 month later...
Update: So to touch on this, I ended up having an intermittent coil pack!! And it just so happened to be the coil over cylinder 6, it may have been the heat, or may have just been unlucky as there shouldn't be ENOUGH heat to kill it back there.
PAT offers a 2 year warranty so I replaced it today and misfire completely gone through the entire rev range.
Currently running an 0.7mm gap with some MSD 34605 terminals which have been lightly crimped at the coilpack end (enough that they'll clip over the coil pack end), and then this is covered by the factory rubber boots found on RB Coil packs. I use a WiringSpecialties coil pack loom which is a custom loom for LQ9 to R33 GTR.
This is what the terminal looks like.
Image result for MSD straight spark plug terminals
Are you happy with how the terminals sit? I'm just using the springs from the factory coils with a bit of stretching and reshaping, but haven't had a chance to do full boost testing to verify it under stress.
Yep, I'm more confident with them than the springs, I was just waiting for the springs to burn out or something like that. Unfortunately my brackets dont suit the extra height that the terminals create, but.. it all works and is sealed! I will be dynoing it in the next month or so and aim for over 400 without touching the gap or dwell anymore.. in fact kind of plan on lowering the dwell from the 3.7ms that it's at roughly at the moment.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
