I wonder if this has massive effect on my misfiring issue :(
well that aint right, so have you probed the alternator terminals ?
http://www.sau.com.au/forums/topic/442670-alternator-problems-some-answers-inside/
a little hard with all my pipe work and hoses in the way.. however I will pull it off after the track day and test it..
lucky car runs a map sensor so will run fine without any hoses attached
will report back :)
if that's the case will need to run new power cabling as suggested, however my battery is in the boot!!
will report back :)
just crawl under the car and probe it
try running the 2nd power cable to the jump start terminal from the alternator if the factory cable is bad
Edited by Dan_J
Why bother. As mentioned the ls coils have been tried and proven and are cheap.
No way would motorbike coils be cheap.
You would be surprised, motorbike coils are that dear, though I still can't find where it says these are motor bike coils, they look like Honda replacement coils, does anyone have a link to where we could that upgrade from :)
Scott at insight and I have discussed a coil upgrade for my 34 some time ago and he suggested Honda coils would be a good upgrade and would mean I wouldn't have to remote mount them or have to run leads
Followed your advice, did a probe when cold voltage was about ~13.6 and down to ~13.2 when I revved it..
Tried it again when the car was hot (after a drive to the shops & back) voltage was around ~13 on idle and dropped to about ~12.8 when I revved it.
This is pretty consistent to the drop I've logged from my ECU.
Now to waste more money :(
Nice, got any more pics of that setup ?
not my setup but have all the bits to get it working :)
skim through the older pages of the thread to find the origin of the photo
yeah mine was a bit intermittent, after constant use the heat in the cable may make the power drop as well .
pretty cheap fix for myself:
$8- ba ford starter cable from wreckers
$5/10 - battery lugs from jaycar
keep the factory cable there and just add another positive cable to terminal in the engine bay to see if its a fix, if not will have to get a 2nd hand cable from a r33 wreck, welding store for the use of welder ground cable which i'm told is priced ok or ebay ;)
^ you're lucky it was just the power cabling.. I tested it on the alternator itself and the voltage was fluctuating...
I'm guessing it's tired, it is an 18 year old car with probably 400 000km on in after everyone having a go at winding back the odometer lol
I had some misfire on boost before I tuned my car last week, that cleared up after installing some ls2 coils I bought 2nd hand for 150 bucks, basically at the stock 2.5 ms dwell they were igniting a mix that was to rich for the stock coils to ignite, set up as coil on plug in wasted spark on an adaptronic 420d, trimmed the stock boot down and put em straight on the plug. Peice of aluminium angle with a few holes and all mounted nice.
After tuning on weds, I'm making 196rwkw with stock turbo, and stock injectors, only at a touch under a bar boost on shell 98
Edited by Scott Black
  • 5 weeks later...
Installed my kit from Rick B at Mojo Performance and the engine is not starting. A few things to note. I have a piggy-back HKS FCon V-Pro ECU that is already tuned. Fully built forged motor with billet crank, Bullseye 375R turbo boosting 2.2 bar, redline set to 9500 rpm, 270 degree 10.8mm lift cams, high flow head, 1000cc Sard injectors, NGK Racing (temp 8 or 9) iridium spark plugs. ECU is still set to stock dwell so I thought I would plug in the new LQ9 coils (Araparts version) and Mojo wiring to test before having my tuner mess with the dwell settings. Well, the car won't start and misfires occasionally during the attempt to start. Any ideas? Is my setup to aggressive for stock dwell? Not enough spark at stock dwell settings? Or is something else going on?
Your setup would have no affect when cranking, and stock dwell will work you coils pretty well, so setting is seriously wrong.
Have you checked voltage ar the coils? Was there another earth to install?
I'm not familiar with that kit, is it possible to connect the coil loom in the wrong order?
Edited by Ben C34
I thought the same (that it should start and run at idle at the very least).
No, I have not had a chance to check voltage at the coils yet. I need to do that. Yes the harness has it's own ground that I have connected/grounded along with the engine harness ground using one of the bolts for the mounting kit that screws into the head.
No, I don't think it's possible to connect the individual connectors in the harness in the wrong order. Also, the kit comes color coded and with a great install diagram to match up to the stock wiring. I verified the colors on all wires and they appear to be accurate.
I don't know anyone first hand who has used the LQ9 coils connected to an HKS FCon V-Pro ECU. Also, the cam timing is not zeroed out so there is some overlap at idle.
The Mojo Performance kit is a plug on coil setup and I have read that without the resistance of the plug wires or resistor type spark plugs that there could be an issue as well.
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
