Yeah it's a greddy copy. The only reason it's not advertised as fitting the R34/Neo head is the IACV is different. You can just make up an adaptor and use the Neo IACV (have seen pictures of it done on this forum) it you could use an R33 IACV, which is probably what I will end up doing.
Okay i have what is hopefully the last quiestion.
I have this from Simon that was posted in another thread
I had my engine on a stand when i removed the relief valve. I was careful to remove the nut and spring carefully, but then as i placed them down something else fell out. It looks like a bucket type thing, will post a pic in a second. But can anyone tell me which direction and order these things go back in. Annoying because i tried hard to keep it all together i just didnt realize there was another thing in there. Also i don't know what ball bearing simon is talking about, i can't see one in there.
yeah i usually do it with the engine upside down on the stand,. so much easier to work on and take sump on and off.
I would have just had no one to help me turn the engine on the stand haha. Also saw you at DCA Simon, car sounded absolutely insane! What exhaust are you running? Is it a fully stainless system?
nah its some bits and pieces of mild steel i had lying merging into a 4" straight bit of stainless haha.
goes alright for a stock rb30 ey ;)
Hahah, what isn't homebrew in your car?! I am going tried and true 3" straight through staino with a 4" tip (just for looks)
Also, progress!
Also, progress!
You may find you need an R33 Clutch master as your current one may impact the ffp
awesome progress mate good to see it all fits! The greddy style intake is definitely a good idea. Did you have any trouble getting the motor into the 32? It looks like the bonnet will close without any issues
Edited by Blackkers
Yep found that out. Had to remove it to be able to drop the engine in. Already have on lined up :)
looking good!
Yeah, so happy with my decision to paint the engine bay. The silver looks really good imo.
Yeah the forward facing plenum is so much better aesthetically, how they should have come from factory IMO. The engine still sits quite high, i explained it in my post in the projects/builds section. Will get a side on pic of it to show how high it sits for you. We quickly dropped the bonnet on and it seems like it will fit if i cut the ribbing out from the underside of the bonnet :)
Cheers man, I'll be using an aftermarket ecu and stepper motor so that won't be an issue. One other thing, how do you go fitting top feed injectors to the 25 plenum, just a case of the right top feed rail?
Also great progress! looks good.
Edited by Huzqld
  • Like 1
The standard Neo rail will bolt right up to it. I never tried to put standard injectors in so i'm not sure if they will fit.
I am using an Aeroflow rail and X-Spurt 1000cc top feed injectors and its all good. Just need to make a spacer to put in between the plenum and rail to space it out for the length of injector you will be using, that's the real trick. Any old rail should bolt up it's just the length of spacer you have to get correct.
you're killing it dude, I'm super jealous
Cheers mate, feels good to be making some decent progress and everything turning out exactly like i had pictured it in my head. Cannot wait to drive it though! Have a private drift day on the 23 August that i would love to attend but i'm off to NZ for two weeks so i don't think i will make it unfortunately. Should be tuned in the next 4-5 weeks though :)
  • 5 weeks later...
Okay so it's getting closer. Anyone know exactly what part of the fuel map i have to change to get this thing running. ECU is NISTune and it was running the Neo before it popped. Literally the only thing that has changed is it now has a 3 litre bottom end and will be running E85 not 98.
I don't want to go thrash the tits off it, just want to get it started and idling, will be keeping it in vacuum, better to be safe than sorry! Will go off to get tuned eventually just want to make sure nothing explodes before i take it to the dyno haha.
which part of the map? all of it
your best bet is to contact your tuner and get them to put some sort of base mape in it for you to suit your bolt ons, but personally i'd have it towed to tuner and then let them do it all from scratch without the added stress of trying to drive something that runs mega rich
I changed none of it.
It will start and run fine as the afm does its thing .
Obviously get on a dyno and get a tune, but I drove mine untuned for weeks before I could get on a dyno.
For the e85 you will need to change the k factor. Refer nistune user guides etc.
Shortly mat should be releasing an update to allow flex fuel along with an injection scaler. Which is better than using k as k changes other things.
I don't plan on driving it anywhere, just up and down my driveway and get it idling in the shed to check everything. I was always going to tow it to the tuner.
Interesting to hear Ben, will crank it and see if it fires up, if it looks like it's not going to I will just leave it to the tuner.
Nistune have released it now, ive seen it all in action and its all pretty impressive!
Some thing else to think about, obviously to late for josh now, but by blocking a oil feed to the head you doing two things 1) creating uneven flow in the head ( not really an issue ), 2 ) creating an air pocket in the block under the plug ( can be an issue )
I am running two 1mm restrictors and a idle while looking through oil cap there is a good solid flow of oil coming out of the cam bearings
And while I'm here IMO a 3" exhaust on a 3.0 is to small, on my 2630 I went from a 80mm jap exhaust which had no restrictions in it ( I checked ) to a twin 3" in to single 4" and the difference is night and day, it is better every where
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
