Hello all,
Time for another get together :)
This time, well head to Katoomba and stop somewhere near the 3 sisters. 2 meet up points for this one. Details as follows:
When: 30th March, 2014
Meeting point 1: Brays Bay Reserve, Rhodes (cnr Mary Street & Concord Road - Oliveto restaurant)
Time: 9:00am (leaving 9:30am sharp)
Meeting point 2: Caltex twin servo M4 westbound (truck stop parking), just behind servo, Maccas and red rooster.
Time: 10:00am (leaving 10:30am sharp)
Once we're at Katoomba, probably stop for a break, maybe a quick feed and or coffee. Then we head to Balmain, to RibTerranean! I'm giving 20% off for all participating drivers. Best ribs in Sydney and definately one of the best for Mediterranean food. Restaurant opens at 5:00pm, so I'm open to suggestions for a scenic drive back to Balmain. We can discuss this at Katoomba.
Please confirm if you will be attending and also if you'll be attending for dinner so I can organise numbers and our table :)
Looking forward to seeing you all again!
James
I also had a thought for the E85 boys, this cruise might be pushing the limits of how far you can go on a tank and I know there's no E85 near the three sisters or lithgow or most of the way back on bells line of road. So are there any of you running E85 that would want to stop at east blaxland? That's the last place on the trip that has E85 until we get right back into Sydney. And that would be a good 250+ k's worth of driving (from the first meet point to Balmain anyway)
Nice thought! :)
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
