FS - Haltech PS2000 with uncut / unused short loom + sensors
Selling a pretty much unused haltech ps2000 with short autospec flying loom.
The ECU was powered up via a smart wire and I began to load stuff in for a 2j.
No longer needed, looking for $2200 negotiable.
I have the mounting kit for it, I don't like them, I have no need for it so I will also include that.
I also have an AEM 3.5 bar map sensor that I will include for an extra $50
I also have a couple of coolant and air temp sensors that I'll never use again, one requires connector with plugs, $20 each.
Probably some other crap that goes with it that I wont ever be using like techflex braid.
Located on the Gold Coast, pick up is welcome, otherwise buyer pays postage.
Hey,
I'm considering one of these with a long loom but your price is quite high for a second hand unit :-(.
Your short loom version is listed on haltech site for $2,354.95 delivered.
OK. I am saving you $155 for a unit that's only been powered up, flashed to the latest firmware and had a supra load file configured to the ecu. Its hardly even been used. Its never ran an engine and its still with the original box, USB cable and software CD.
No one stopping you from buying the same thing direct from haltech for more money or you can save a little and buy mine.
I dont know what gives you entitlement to comment that my second hand ecu is priced quite high but I honestly don't care.
If you want to post links up to the same package as I have that's sold or advertised for less than what I'm asking for then please feel free to do so.
If my price is an issue for you then look elsewhere. I'm in no rush to sell it and could easily still keep it for a future project.
Thanks
Did you even read the first post I made?
$2200 negotiable, with the mounting kit and a number of sensors at a reduced price?
If you're interested then why don't you put your money where your mouth is and make me an offer?
Worst I can say is no.
I have an engine lined up that I can use it for but if someone wants to give me a good offer then I'll sell it and wait for their Elite ecu to be released.
Either way, I don't really care as this will run the engine just fine.
Thankfully neither one of us really care :-)
Not suited to my needs as chasing one with long flying loom which comes with new, however alone is $500+
unavoidably will be buying one new closer to build completion.
GL.
Haha
You're a Muppet.
Firstly you cannot even read then you whinge and moan that its not cheap enough now you're saying its not suited to your needs.
Have fun paying full retail.
f**king idiot
  • Like 2
Bla bla bla said the foul mouthed bogan!
Oh hang on there's a heap of people lining up to buy your overpriced sh!t.
Full retail? Ha!
Right back at ya douchebag :-)
Edited by pauls
You want to sort this out in person?
Overpriced shit? I don't get why you cannot get it through your head that it says negotiable. Its been negotiable since the day it was advertised.
Dumb people like yourself annoy me. You cannot read. You continue to comment on the price after being told several times that its negotiable. What is so hard to understand about that?
Calling it shit too? You've admitted that you'll have to buy one yourself!
You need to put your lack of money back into an education because you really are one dumb f**king idiot.
I'm glad you continue to post, everyone can see how much if a complete retard you are! Please keep posting too.
Edited by [200]
  • 1 month later...
  • 4 weeks later...
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
