Hey guys new to this so tell me to fxck off and search or what ever but i have done a wee bit.
So, i just shimmed my diff in my r32 as per the diy instructions worked a treat nice and tight, pretty much locked =)
Now i have this weird knocking noise after releasing the clutch into gear and driving slow like something is buggurd in the gearbox.
There is no movement in the diff or shafts and the driveshaft seems good but you can turn it a wee bit and its like the gearbox has a delay to engage, so what in the gearbox would cause this play/knock?
Still drives mint in every gear no noises or crunches
the car was perfect to drive before the tighter diff was in or maybe it wasnt enough to notice it i dont know.
cheers please help =)
https://www.sau.com.au/forums/topic/440501-gearbox-issue-you-might-know/
if there is a clunking noise when you apply or remove power, and you've just shimmed the diff, by far the most likely reason is the backlash is not set properly. Are you confident you followed the right procedure there?
Yeah pretty confident with the car jacked up when you twist the drive shaft back and forth the halve shafts turn with it almost no play there but at the gearbox end you can twist it a bit before you can hear it clunk or engage, is there anything in the gearbox that could cause this keeping in mind that everything else is mint no noises no crunches shifts perfectly etc
Drop the tailshaft and turn the gearbox yoke independently. Then do the same for the diff. Work out where the problem is, because it can be deceiving when it's all hooked up. I'd agree that it sounds like you've got too much backlash in the diff. There's not a whole lot in the gearbox which would cause a delay to take up, unless you're missing teeth or something.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
