use a strap-on you will still have a small dick .............and everyone knows it
sport a GTR badge on a GTS/GTS-t and everyone knows ..........................you have a small dick ! (metaphorically speaking of low self esteem)
Haaaaa haaaa I nearly chocked on my tea. :-)
  • Like 1
Let the kids throw all sorts of fake stuff on their cars.
There's no reason to be butthurt.
A true enthusiast knows when there's a fake around, whether it be a GTR badge on a civic or a Mugen sticker on a hyundai, have a chuckle and let the kids that don't know any better believe that shit.
Only a true enthusiast won't fake-up their ride.
It makes it much easier for true enthusiasts to see who is who in the scene ;)
Kinda like the kids trolleys at Bunnings with the red ball on the vertical stick thing, you can see them coming, so you keep your distance.
Mark :)
PS: Reminds me of the kids with their JDM stickers (Wakaba, yellow/green V-shaped sticker) that actually mean you're an inexperienced driver (Jap version of an L-plate)! Hahahaaa kids these days, all the information at their fingertips and yet they still screw up!
  • Like 1
Mark :)
Are you positively annoyed friend? Bro?
1277956d1384105744-how-sustainable-consu
Edited by Elegant Skyline
In speaking of small dicks, i have come forth with a statement,
we all know R32 GTRs have the smallest dick out of all GTRs :D
  • Like 1
You might as well make your following posts in this thread start with "I'm obviously a troll so I'm just posting something stupid to try and cause trouble".
Can someone kick this thread over to wasteland so it can be given the treatment it deserves......
  • Like 1
You might as well make your following posts in this thread start with "I'm obviously a troll so I'm just posting something stupid to try and cause trouble".Can someone kick this thread over to wasteland so it can be given the treatment it deserves......
Fantastic idea. :-)
4 wheels keep on turning Loud RB keep on burning Trolling, Trolling, Trolling on Gee Tee Ahhhhhh.
CCR your my kind a guy rob,if I was single and twenty years younger. :-)
How To Suck at Trolling, written by Elegant Skyline
1. Think of an awesome trolling idea
2. Rush to post your awesome trolling idea on some random forum
3. Watch your awesome trolling idea fail, miserably
4. Try to act cool and carefree
5. Watch your awesome cool acting fail, miserably
6. Pull out a last ditch trolling idea, one that you saved for emergency purposes
7. Watch it crash and burn, miserably
8. Bail!
9. Fap furiously, then repeat the above steps on another random forum
  • Like 1
Your obvioulsy a big (edit) who brings shame to the Skyline name and reputation, go buy a Lancer and put a Evo body kit on it so we dont need to associate with you, then go mix with your own kind of jerk, you can all go and ski each other (visual joke) over your fully sic hectic cars.
Your Skyline would have a shit reputation if it wasnt for the R32 GTR, im guerssing you own a R34 GTT because you couldnt afford the R34 GTR, ill bet you have a GTR badge on because of this and are cut because people are mocking you.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
