hey all i am helping my brother sell his car it is located in the ACT details are as follows cheers.
http://www.carsales.com.au/private/details/Nissan-Skyline-1989/SSE-AD-2559794/?Cr=0&sdmvc=1
For sale is my R32 skyline, ive owned the car for roughly 3 years. Second owner in Australia since being imported from japan. The car has tasteful modifications, with alot of potenial to be compeitive on the track if desired. The car has not yet seen the track, nor has it been drifted. The car runs very well for its age and is alot of fun to drive. Its Currently running 193kw atw on 15psi, new turbo setup was installed less than 300km ago. All mechanical work carried out by Trojan motorsport in Mitchell ACT Below are all major modifications.
Please no swaps enquiries, only looking for a straight sale
Isc tube n fin intercooler
Splitfire coil packs 5k old
Platinum aridum plugs
3" custom exhaust.
1000cfm metal race cat.
Rb25 gearbox. New thrust, throw out and input bearings. New breather lines and redline oil.
Excedy heavy duty clutch with custom clutch tongues
Custom single piece tail shaft.
Hsd adjustable coilovers
Nismo dash unit.
GKTECK Deep Dish steering wheel
Nismo gearbox mount.
Turbosmart bov
Kinugawa turbo, full braided lines
Tomei fuel pressure reg255l/h fuel pump
Fuel pump rewired
New windsheild
Turbo timer
Boost gauge
Front, mid and rear strut braces.Under castor arm brace.
Vented and slotted brakes
Reconditioned sumitomo calipers.
Fixed back bride replica seat
Sony head deck
Carbon wrapped interior parts.
Reinforced nismo clutch bracket.
New master and slave cylinder
New steering column New r32 headlights Smoked indicators
Autostrada modenas
Kumho ku36
Front camber arms
1989 R32 GTST TYPE M.
any questions please email.Looking for $10, 000 ONO, feel free to either sms 0431094694 or email [email protected] any further questions or enquires. I am a shift worker and cannot answer phone calls at work.so sms or email is best,Thanks very much for your time.
i (jazz) can also be contacted for info regarding lachys skyline on here
post-86368-0-14088500-1394842679_thumb.jpgpost-86368-0-42143800-1394842709_thumb.jpgpost-86368-0-58974700-1394842729_thumb.jpgpost-86368-0-36803900-1394842749_thumb.jpgpost-86368-0-02482000-1394842766_thumb.jpgpost-86368-0-14927500-1394842783_thumb.jpgpost-86368-0-54028600-1394842839_thumb.jpgpost-86368-0-56035400-1394842862_thumb.jpgpost-86368-0-04373500-1394842888_thumb.jpgpost-86368-0-66633600-1394842922_thumb.jpgpost-86368-0-46409900-1394842946_thumb.jpgpost-86368-0-19257500-1394842971_thumb.jpg
https://www.sau.com.au/forums/topic/440518-193kw-r32-type-m-gtst/
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
