At last mallanats....
Have taken it off the road, throwning up whether to put a supercharger on it or be a little different and turbo it....
So far turboing is winning..... just!
Major positive is the turbo can be concealed under the bonnet, where as the supercharger hangs out up top. As i do drive it on the road from time to time
1901673_298589260296382_4913958528555740
1926037_10203374907436240_94273717006146
  • Like 3
  • 3 weeks later...
So, I might be a little off topic. I built this when I was 15 and gave it to a mate to look after when I was 20 and just about to go travelling. That's 23 years ago and he's still got it. I "borrowed" it over the weekend and took some shots for the record. If you squint it could be real...and it's certainly a beast. 934 Turbo RSR.
  • Like 2
  • 1 year later...
Yes! That looks amazing! What a job you did on it for a 15 y/o!
She's no weapon but a good cruiser,attachicon.gifImageUploadedBySAU Community1443270304.509513.jpg
My first car that I still have,currently off the road being a slow project
attachicon.gifImageUploadedBySAU Community1443270460.273774.jpg my race carattachicon.gifImageUploadedBySAU Community1443270620.041672.jpg
And my for fun burnout toranaattachicon.gifImageUploadedBySAU Community1443270757.516983.jpg
Some seriously cool cars in that lot.
my S14 after a wash...
Damn that looks really clean!
not sure what happen to other photos
Love Impala's! I'd hate to know fuel cost.
  • Like 2
  • 2 months later...
My non-skyline weapon... offroad weapon that is :D
I'm with you...
on my way out of The Lost City...
and over to Maingyu Marragu Rock
Maiyngu%20Marragu%20Rock-6_zpsytqsdlfq.j
Offroading is whole lot of fun (as well).
  • Like 1
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
