after some advice, fitting a known good r34 motor to a gtr, is it advisable to change to arp rod bolts without changing bearings? are the factory bolts a weakness? Id rather not disturb the short motor but if it will be ok to keep the bearings and retourque without taking the caps off im happy to. Also running 264 cams , whats the thinnest head gasket I can use to bump compression up?
https://www.sau.com.au/forums/topic/440541-arp-rod-bolt-help/
I'd change to arp rod bolts with 400rwkw. (known a gtr to lose a bottom end on the dyno due standard rod bolts at that power level) But there's more than just putting the bolts in however, you need to torque them up then hone the main journal rod end for round and correct size so it's pull engine apart time. I'm not sure how you'd get the rod bolts in without disassembly though (if that's what you mean?)....That said, I have a spare set of standard rods with arp rod bolts that have been resized/honed and are ready to go, pm me if interested
Ah, what rods are in the engine?
If you have standard rods the bolts need to be press fit into the main rod body, requiring removal from engine. I'm guessing you have arp rod bolts that are for aftermarket rods that screw in from the cap side? (These won't work with stock rods- arp also do rod bolts for stock rods that are different). See attached pic- left is aftermarket and right is standard, you can see the difference in how the bolts fit.
Edited by doo doo
What do you know about the history of the block? If you don't know for sure just bite the bullet and pull it apart, measure and replace as necessary (rings and bearings or whatever is necessary for your more than 400Kw goals).
My first reply was probably a little short. There have been a few cars these days running stock rods and bolts over 400rwkw. The main reason I turned away from changing them is because as mentioned above, by the time you fit them, resize the rods, fit new bearings. You will have the pistons out and the head off, it can easily escalate to a full engine rebuild. So it's a bit of a weigh up between, do you risk running the bolts over 400rwkw or invest more money than you were planning on the engine.
At 400rwkw you have more to worry about than the rod bolts
I would be putting a Tomei oil pump and large volume baffled sump on it before i bothered with the bolts. If your that worried about it all letting go rebuild the whole thing and be done with it because you will never be happy with it until you do
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
