Hey there, just joined the forum and also just got me a 91 r32 GTR, I'm kinda familiar with the car, didn't see or talk of many growing up.
But I'll just get strait to the point, I've got this great car and i want to throw some money in it. So far its stock I've got a basic understanding of modding a car but i figured because there's so many people doing it on here maybe you could point me in the right direction. Any help is appreciated thanks.
Consider yourself pointed in the direction of the rb26 dyno results thread stickied in this forum.
Or by pointed in the right direction do you mean have exactly what to do to your car spelled out to you based on not specifying a budget or goal?
Sorry if that comes across harsh,but seriously all the info is on this site,and your question can't be answered as theres not enough info.
Edited by superben
No worries dude.
There is obviously heaps of advice to be heard, but without having a goal and budget in mind it's all a waste of time
I would start with a full change of all fluids,plugs, timing belt,tensioner,cam seals, etc to make sure you are starting with a solid base.
One you start modifying it you are opening up a bigger money pit!
Something tells me this is either a troll or someone who bought a car before doing any research AT ALL!!!!
You have a stock R32 GTR that you are wanting to smack 2JZ's with and run a 9.66....... do yourself a favour and sell it as i can see the next thread being 'i got done street racing' or 'my engine blew up, what do i do now?'
lol, i just re read it and read it properly, sorry dude :(
As has already been said, the first thing i always told people to do was a fluid change, water pump and all timing belt bits (belt, bearings, bolt etc.
Good oil is always going to help and i have ALWAYS used Motul 300V 20W60. Have used it in so many cars with minimal wear on even race engines.
A decent catch can will help prevent any blow by going back into the intake which helps in many ways
Last but not least pray to the car gods that the oil pump doesnt fail
Full service, upgrade the pads, get an oil cooler and take it to track days. Don't worry about the Toyota engine down the street.Once you start tracking your car, you'll know where to spend your money.
Rebuilds, mostly.
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
