Hi, I am about to install garret 2860-5 into my r32gtr. Is it a good idea to also install some aftermarket cams and if so which would be a good set.
At the moment I am running 270awkw on e85.
It also has all the other good bits and so it's time to install turbos just wondering if aftermarket cams is a good idea or not.
Thanks
Here is a list of what i have done
JUN B.L Exhaust
HKS Fuel rail
HKS 1000CC Fuel injectors
Sard Fuel regulator
Walbro internal fuel pump
Greddy oil re - location kit
Greddy oil cooler kit
Nistune chip
Turbosmart bleed valve boost controller
Splitfire coil packs
New spark plugs
E85 fuel conversion
JECS AFMS
APEXI AIR INTAKE PODS
Greddy coilovers
Whiteline front sway bar
Whiteline rear sway bar
that is a list of what is in the car.
I mainly use the car to do Hillclimbs and is also a weekender.
I like high revs if that helps
If it's for hillclimb i wouldn't even go -5's. Go -7's and put E85 through it. Though that's just me.
So the engine is not rebuilt?
In that case don't spend the money on cams,save it for a rebuild down the track.
This.
If not
Tomei Type B.
  • Like 1
You can, if you ask Tomei nicely, get them to supply you with a number of different cams - you dont have to go typeA/B/R. Eg the exhaust on a type A is 252 degrees that on a B 260. But you can (Or could) order up a 256 degree cam if you wanted.
Anyway with E85 you would lean toward a type B - but again it all depends on how much you want to grind out of the thing and how much low end losses you are prepared to live with. I once had type B's with -5s (albeit on petrol) and as a hillclimber they sucked balls. You cant get out of the slower chicanes as the thing takes forever to get on boost. Type A exhaust cam and a slightly smaller inlet cam made a good difference (Like near on 40 hp at 4000rpm) without killing the top end but again petrol and E85 are different things.
Edited by djr81
  • Like 1
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
