I see greenline does them.
"Mines rb26 shore pro 2". They were about $1600 when I was looking, that includes buckets though. There isn't a hell of a lot of result out there with them, I'd say that would be due to price.
I was going to run them before I decided to go even more aggressive.
If it's for hillclimb i wouldn't even go -5's. Go -7's and put E85 through it. Though that's just me.
Concur... Most hillclimbs being lower speed (under 140km/h), -5 are not the right selection for such escapades.
So if -5s are already there you want the max response you can, stock cams and some cam gears set to bring on boost early as possible without worrying about the peak figure as it's the middle area that's going to bring home the silveware
haven't got the -5 as yet just doing my research and from reading some forum threads it seems that the -7's come in earlier but really drop off at around 7000revs is this correct?
I like a high revving engine would get the -7 but would prefer to be changing gear closer to 8000revs ....
Thanks for the info Piggaz found them on green line your right not cheap but i will speak to my tuners and if they think there worth getting i will get them..
nope. Mine Hold 21PSI all day. Depends on the engine i suppose. Why do you want to change at 8000RPM? there is no reason for that. That's just an engine waiting to go bang sitting on the redline like that. Until you forge the engine don't even go near that. Even then i wouldn't.
Anyway if you are planning on doing hillclimbs get the -7's. You will get much faster times with them. And they can still run decent power. I'm sitting at 320KW on 98. To go -5's for hillclimb is a huge waste of moneys.
  • Like 1
thanks it tuned for e85 at the moment.. thats some pretty good numbers ok then so its -7's is it worth also getting the Tomei exhaust manifolds and extension dumps at the sometime ?
No to the exhaust manifolds (between the engine and the turbo) Yes to the dumps.
Why 7's & not 9's?
  • Like 1
to be honest I'm not too familiar with either just doing my research.. i thought the -7's are bigger and would get more power than the -9 and thats why..
Edited by boobeedoobee
DEFINATELY no to the exhaust manifolds. I have been two sets myself, one set didn't last 1500 km before I blew a hole in number 1 runner. That and when I put on some tickled stockers there was no difference on the dyno or the road for that matter. However, they make a great paper weight or a nice looking door stop.
  • Like 1
-9's will net a fraction more.
  • Like 1
Good work. I only went through one set but I did manage to crack both of them. Winning.
  • Like 1
No to manifolds man. I'm making 472 rwkw through -5's on stock manifolds, they have been matched to the head and turbine housing though.
Dumps - HPI, Tomei, Midori. Take your pick and if you want to be really fussy, match the front pipes to the dumps so there is no lip there.
  • Like 1
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
