I see greenline does them.
"Mines rb26 shore pro 2". They were about $1600 when I was looking, that includes buckets though. There isn't a hell of a lot of result out there with them, I'd say that would be due to price.
I was going to run them before I decided to go even more aggressive.
If it's for hillclimb i wouldn't even go -5's. Go -7's and put E85 through it. Though that's just me.
Concur... Most hillclimbs being lower speed (under 140km/h), -5 are not the right selection for such escapades.
So if -5s are already there you want the max response you can, stock cams and some cam gears set to bring on boost early as possible without worrying about the peak figure as it's the middle area that's going to bring home the silveware
haven't got the -5 as yet just doing my research and from reading some forum threads it seems that the -7's come in earlier but really drop off at around 7000revs is this correct?
I like a high revving engine would get the -7 but would prefer to be changing gear closer to 8000revs ....
Thanks for the info Piggaz found them on green line your right not cheap but i will speak to my tuners and if they think there worth getting i will get them..
nope. Mine Hold 21PSI all day. Depends on the engine i suppose. Why do you want to change at 8000RPM? there is no reason for that. That's just an engine waiting to go bang sitting on the redline like that. Until you forge the engine don't even go near that. Even then i wouldn't.
Anyway if you are planning on doing hillclimbs get the -7's. You will get much faster times with them. And they can still run decent power. I'm sitting at 320KW on 98. To go -5's for hillclimb is a huge waste of moneys.
  • Like 1
thanks it tuned for e85 at the moment.. thats some pretty good numbers ok then so its -7's is it worth also getting the Tomei exhaust manifolds and extension dumps at the sometime ?
No to the exhaust manifolds (between the engine and the turbo) Yes to the dumps.
Why 7's & not 9's?
  • Like 1
to be honest I'm not too familiar with either just doing my research.. i thought the -7's are bigger and would get more power than the -9 and thats why..
Edited by boobeedoobee
DEFINATELY no to the exhaust manifolds. I have been two sets myself, one set didn't last 1500 km before I blew a hole in number 1 runner. That and when I put on some tickled stockers there was no difference on the dyno or the road for that matter. However, they make a great paper weight or a nice looking door stop.
  • Like 1
-9's will net a fraction more.
  • Like 1
Good work. I only went through one set but I did manage to crack both of them. Winning.
  • Like 1
No to manifolds man. I'm making 472 rwkw through -5's on stock manifolds, they have been matched to the head and turbine housing though.
Dumps - HPI, Tomei, Midori. Take your pick and if you want to be really fussy, match the front pipes to the dumps so there is no lip there.
  • Like 1
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
