hi mates i got a car recently and noticed it has no water lines on the turbo so i wanna put some on it. i think it had a oil only turbo at some stage. the water hole on the block it there with the banjo eye thing in it with the metal line crimped to block it but what i need help with is the other line that is usually behind the motor (does it come from plenum?)
is the one on the block the feed or return and what can i do for the other line? i cant see anything blocked off to reuse so need help.
thanks mates
https://www.sau.com.au/forums/topic/440600-rb20-water-lines-for-turbo/
I simplified the cooling circuit when I changed the intake manifold.
Now the return goes from the turbo directly to the water pump bypass.
On the original circuit the return goes partly to the radiator and partly to the waterpump bypass.
