So I've gathered items for a rb25de +T build.
Before I get the whole "why not just do a straight conversion ?" I'll just tell you now you can't do it this cheap!!
So far I've acquired a full rb25de neo with 165-170 psi across all 6 and only 120xxx kms on it for $100.
A full rb25det neo intake manifold with injectors and rail etc for $200.
Already got braided turbo lines and a neo factory turbo manifold also.
Will be running a factory op6 turbo and cosmetic 1.3mm head gasket. Oil cooler and relocation kit. Premium pulp and either 25det ecu, IMPUL, nistune or megasquirt and FMIC
Since I don't want to re loom, I've decided to eliminate cold start which I'm not fussed as I've never owned a car where cold start even worked before I got my current r34 lol. So I'm going to buy and bolt up an aftermarket 76-80mm throttle body on the standard intake and re wire the DET TPS to the DE loom. Shouldn't be difficult as both have 6 wires. I'll just need a Pinout diagrams.
Also will need to rewire the IAC valve or delete it though nistune is an optional thought. And re routing water lines may be a bitch.
As for the head, the na neo has smaller intake ports then DET, so decided to get them tapered out and polished to DET neo size to run the gasket and manifold smoothly. Also at the same time, I'm getting the exhaust valve ports die grinded to remove castings to run the bigger DET neo cam or buy tomei drop ins as shimming is the same between both engines.
Anyone done this before that can shed some insight ? Thoughts ? Criticism ?
https://www.sau.com.au/forums/topic/440616-neo-det-build/
And......there goes the difference in the money.
https://www.sau.com.au/forums/topic/440616-neo-det-build/#findComment-7230365
If you already had the head off, might as well just get a neo det head instead. You do want to swap out the exhaust side cam as that thing is rubbish (also fixed by getting det head). I very much doubt you want to touch a stock ECU with that setup,I would suggest considering (if within budget) something more programmable (haltech etc). last I checked running RB25 with nistune was not straight forward (most used z32?).
Otherwise i'm interested to see the cost benefit of grinding the DE head, make sure you write every cost down and see what you come out with. keep on with this project!
https://www.sau.com.au/forums/topic/440616-neo-det-build/#findComment-7230675
Should have left the head stock for improved gas speed imo. Aftermarket 80mm throttle? lol.
Anyway, isn't this in the big boys section? The NA+T's are usually relegated to the NA section... Like the 10,000 other threads just like this.
https://www.sau.com.au/forums/topic/440616-neo-det-build/#findComment-7230716
Yes, neo ecus can be nistuned straight up and will do everything I need it to do.
Also, the idea of the 80mm throttle was not for the size as I'll only be running 76mm piping but just to remove the cold start and butterfly etc that's associated with it.
https://www.sau.com.au/forums/topic/440616-neo-det-build/#findComment-7230925
What are you talking about? There is no "cold start and butterfly associated with it". The cold start stuff is on the back of the plenum. The butterfly on the Neo DET TB is the traction control. If you want to not use it, fair enough, but at least know what it is that you are doing.
https://www.sau.com.au/forums/topic/440616-neo-det-build/#findComment-7230931
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
