Hey guys, I've got a R34 GT-T.
I've had it for a while and have heard about the "consult" cable. I have a stock ECU, I was wondering a few things about the whole cable:
- What are the main things I can do with the cable and my car? (I have a reasonable amount of computer knowledge)
- Is it hard to use the cable?
- Is it worth buying?
Thanks heaps guys :)
can't seem to find the edit button, but along with those questions I have another;
Why are the prices ranging for the consult system, from like $15 - $400 on ebay? isn't it just a cable you connect, would have thought it would be a cheap thing to get?
The more expensive units are hand held readers which display codes on an LCD screen, the other cables are just an interface between the car and a laptop. Years ago I purchased the ECUtalk cable, which is still around $100, nowadays there are lots of cheap ones available from china (Im sure the ecutalk one is chinese too...)
The ECUtalk has a site, with links to the chip manufacturers site where they list USB drivers for various operating systems. I have no info on whether the cheaper ones will have the same support, if any at all.
http://www.ecutalk.com/interface.aspx
http://www.ftdichip.com/Drivers/VCP.htm
thanks heaps for that.
does anyone know any examples of what sorts of things you can see with the cable, e.g - compression tests? etc
and is it worth getting a cheap like $15 one?
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
