R32 coupe GTST black
BM50 90
Black electric mirrors 60 ea
Head lights 125 ea mint condition
34 mm water temp adapter 10
Drivers window switch 60
5 bolt shafts 100 pair
PAIR OF 32 Seats, drivers has small rip, passenger immac! 50 dollars, taking up space, want my space back, cheeeap seats
A pillar covers 25
Floor carpet 40
Gab front shocks has springs on them assume lowered 70
Stock rear springs 60
Passenger door glass 20
Drivers door in good shape, with window in black 140
Seat belts, 60 each
Steering wheel centre button, 10
Lower control arms, 60 each, 100 pair
Castor arms 40 each
R33 s1 coupe Black 141,000kms
RB25DET Motor with all accessories, Loom, ECU, turbo (doesn’t look like rb25 std turbo, still Nissan though)
It was running and driving fine but you could hear a slight tapping noise from timing case, assumed idler/ tensioner pulley. Was louder with timing case off. Considering this I have priced it to go!
Also had great oil pressure and spooled up well.
$1200, cheapest complete rb25det you will find.
Complete RB25DET manual conversion.
good condition box, shifted very smooth, no noises
Flywheel, clutch, clutch master, clutch slave, clutch lines, clutch pedal, interior surround (needs boot), shifter, gear knob, tail shaft. The lot.
1450 firm
400 without box
Complete front and rear 5 stud conversion, big 4 pot brakes
Great for S chassis and NA skylines plus others!
Good pads and discs, pulled up really nicely
Hubs, brakes, front uprights, brake lines, brake pads, brake discs, everything you need.
500
Complete rear subframe with all arms only missing hubs/ brakes
with
great upgrade for r32/s13’s and such.
With diff/ shafts 400
without diff/shafts 250
Stock rear springs, great shape, 70
LSD differential, good condition 175
5 Bolt drive shafts $100
Drivers door, excellent paint
- 80, glass without regulator
-130, glass with regulator
Passenger door,
Complete with glass and reg 130
Door trims
50 ea
Window regs, 70 each
Floor carpet, good condition
40
Seat belts, 60 each
Interior plastics
$10-$30
Dashboard
35, vents at front bit cracked
Steering rack 100
engine cross member 90
Auto Rad, works in manuals too 70
Bare r33 shell, Mint rear quarter panels, not rolled, awesome paint, 150
Front guards
Drivers 80 mint condition
Passenger 40 slight bend at top
Lots more r33 parts as I am stripping the car
Parts to suit many cars
Green label Air flow meter 60 bucks
I have 2, good upgrade for rb26
Green label afm, not working, has been opened up and glued back closed, 15
6x Series 1 coil packs, perfect working order 80
6x Series 2 coil packs, I have never used them, so unknown 50
Rb25det coil pack loom, works fine, few chipped plugs, 40
2x Pod filter adapter 15 each
ALL LOCATED IN ALTONA, VIC
CAN HELP WITH DELIVERY/ SHIPPING
DELIVERY REQUIRES DEPOSIT
PRICES RELATIVLY FIRM
Although, Discounts if you buy more than two things.
SMS me for more info and photos
0433200452
I will try check this often but I forget about it
  • 1 month later...
Hey, have you got the the boost solenoid setup? im after the line from the intercooler piping towards the wastegate / boost solenoid, it has a red stripe on it as it has a restrictor in it to allow the 7psi 2nd stage.
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
