i got my 370gt coupe through a dealer. after a month,i found my fuel gauge is not measuring the fuel amount
properly,like fuel gauge display always up and down ,even the car have full fuel,it would still give me a
warning of low fuel, then i brought back to show dealer, he said he would fix it for me ,after a few weeks
process,still cant fix it, end up the whole computer system is break down***the one manage all sort of
electrical centre unit: gps ,audio not working ,disc cant play ,air-con on and off by itself and system restart
when i am driving every 5 mins***
the dealer is going to response,it is already being 3months, they still cant find the part to replace it, even
infiniti/nissan cant help at all.
anyone know where to get this part in or know any write off 370gt that i can just buy the part from there?
PLEASE HELP ME OUT GUYS
really appreciate
Have they changed the battery and checked the connections? Sounds like a voltage issue to me, unless they have introduced a fault trying to fix the sender.
The senders in the fuel tank may be dirty, you can clean these with contact cleaner, sometimes comes good. There is a float sender in both sides of the tank to measure fuel level which then goes to the BCM I think.
i don't think there is a issue with battery , as one of the 370gt importer pulg a computer from other 370gt to my car , it does work again, so pretty sure is a computer issue.?
thanks for advise.
do you know where i can get a cleaner to clean it?
Metho, ethanol or contact cleaner will work, you should have no trouble finding contact cleaner an any auto parts store. Make sure you get replacement tank Orings from Nissan.
What computer did he replace, the engine ecu or the body control module?
ok i see, thanks
getting the computer which managing the center unit ,audio,air-con etc.....
I don't know if this will be helpful at all or not but when I was mucking around with my system I found that if you remove the 4-wire ribbon which runs into the actual touch screen overlay you will lose all of the system controls. I have no idea why the touch screen controller is directly connected to the rest of the systems but I found that the AC/Radio/steering wheel controls etc would all stop working with this 4-wire ribbon disconnected.
I would be pulling the entire facia apart and checking all of the connections because it seems that the systems are all interconnected. It may just be that they mucked around behind the stereo and something is now loose. It's pretty easy to pull apart and put back together.
My understanding of it was the thing would randomly reboot.
Screen output sits on the UART lines via a controller. Never delved too deeply into it though.
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
