if it dose not make sense its because I was at work typing fast not to be caught lol.
I have a s1 c34 stagea and am looking to upgrade the ecu. I read hear a while ago that u could use a z32 ecu in the s1 so it could be nistuned. so I was after all the info on making it work. a guy hear in wa has a ecu but I not know if it can be plugged in to my existing loom. the stock ecu plug now is a grey plug
https://www.sau.com.au/forums/topic/440675-z32-ecu-in-a-s1/#findComment-7231452
I have heard that story too but I don't know anyone who has done it. You are looking for an ECU from an auto Z32 but it is far from a simple job and as I say I am not even sure that it will work. You could try emailing Nistune as I am sure they would know about it if anyone has done it.
https://www.sau.com.au/forums/topic/440675-z32-ecu-in-a-s1/#findComment-7231739
Sorry I don't know much about the Nistune options either, but I do know a Z32 ECU would be a full wire in job which is a bit of stuffing around. You may well need the z32 AFM as well but getting the ECU in and wired is the first trick.
https://www.sau.com.au/forums/topic/440675-z32-ecu-in-a-s1/#findComment-7231795
or swapping pins. but I am still finding out. according to a few tuners hear the triptronic has its own module to control that. so he said u will just need to find out if the auto shifts the same still. the awd is not affected as long as the signals to the awd module are right
Edited by whitenight27
https://www.sau.com.au/forums/topic/440675-z32-ecu-in-a-s1/#findComment-7232663
The only other time I have heard of a 34 ecu in a stage a was in a thread in forced induction. A guy from the UK had it done, and the trans wouldn't shift properly. And heaps of power was missing"
I can't remember exactly but the title had something to do with t2 turbo,as apparently that's what his tuner fitted....
Anyway I'm predicting this will be way harder than you think. 4bidn1 has done a neo conversion so would know a thing or two about the neo Ecu's hidden traps.
https://www.sau.com.au/forums/topic/440675-z32-ecu-in-a-s1/#findComment-7232730
yer I am talking with a guy in the uk about his s1 that was running a r34gtt ecu. trying to get all the info. if I can get a r34 ecu for bugger all I will try what a tuner hear said. to plug it in swap the cas wires and see how it runs if it starts. then take it for a slow drive to see how the auto is. if none of that works will just look as a decent piggyback ecu
https://www.sau.com.au/forums/topic/440675-z32-ecu-in-a-s1/#findComment-7232757
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
