Left over parts from wrecking my Black R33 GTST S1.5.
All large parts are pickup in Macleod, VIC, but some smaller ones can be posted at buyers cost.
All parts are in pretty good condition unless stated and prices should be pretty good unless it's a bit of effort to get the part out.
Check out the list and let me know if you further info or pics.
HKS Pod filter with adaptor - Needs new foam $30
Intake manifold - No sensors $50
Engine mounts $50
Radiator overflow bottle $20
Aircon condenser with piping $50
Power steering pump $75
Power steering reservoir $20
Alternator $65
Fuel pump - No label but was fine for 285+rwkw $60
Clutch master cylinder $50
Manual pedal set $60
Tail shafts $60
Exhaust
Decat pipe - Straight 3in bolt on $30
Wheels
Impul NS-01 light weight racing 17in inc Federal tyres, 70% frt, 40% rr $600
Front 5 stud hubs $60
Spare space saver wheel $40
Stock Suspension
Front castor rods $75
Front upper control arms $50
Rear control arms $75
Brakes
Discs Front $40
Master brake cylinder $50
Exterior
Body shell Still complianced and registerable $400
Rear reinforcement bar $80
Bonnet latch $30
Side skirts Stock or type M $100
Spoiler - Series 1 No stop light and scratched $30
Bonnet Black - resprayed $120
Boot Black $50
Front wheel liner Front RH $15
Series 1 tail lights pair $60
Indicators Nismo Side - clear pair $35
Interior
Front Recaro $160
Wiring loom $120
Rear seats $40
Seatbelt set minus front buckles $60
Instrument panel $60
IP cross car beam $50
Centre console $20
Headliner $30
Handbrake front section $40
Taco - 4in with shift light $60
Pillar trims $20
https://www.sau.com.au/forums/topic/440678-vic-r33-gtst-s15-wrecking-leftovers/
Steering wheel?
Still on the car but the edging is not in great condition why I hadn't listed it yet.
If still interested I can at least put up a pic tomorrow.
Parcel tray ?
You'll hear it before you see it
Sorry mate, already sold.
The list above is pretty much everything that's left other than a large bucket of bolts that would hold the whole car together.
hey man, how much for the indicators + postage to melbourne (3040)
$30 pickup in Macleod or $40 delivered to 3040. Still in excellent condition!!
Rear wiper arm with plastic bolt cover?
I thought it was gone but I actually still have it with the bolt cover. Pic attached.
$25 pickup or $35 delivered.
Edited by Steg33
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
