Hey guys got the bad news today that my RB25 is toast in my S1 RS4. Pretty frustrating considering It hapened after owning the car for less than a week.
What RB25 will fit in without any major modification? Do all AWD versions from 33's and Stageas fit?
Obviously RB25 neo is completely different and would require the correct ECU etc?
Ive change alot of old toyota engines but nothing quite this complex is it a tough job? Im overall pretty handy but is there something I should look out for? Can the engine be lifted from the top or does it need to be dropped out with the whole subframe of a hoist? Do I seperate engine and box?
Any help would be great guys.
https://www.sau.com.au/forums/topic/440680-replacement-engine-for-s1-rs4/
Shouldn't be hard to find another stagea s1 complete engine and cheap too. Where are you located?
As for the change over I found it easiest to take gearbox and engine out together, but don't forget to label all of the lines and hoses. That is what stuffed me around the first time.
Challenge auto wreckers in Sydney have complete s1 engines advertised for $1200 they also do freight. But you being in S.A should make it easier from what I remember there are a few jap import wreckers around radalaide or even import monster in Vic should be able to help you out.
Alternatively you can get your one rebuilt the most expensive thing is labour so getting it out and putting it in yourself will save heaps.
Probably a bit early into your ownership but would be an ideal time to get a Neo motor c/w ecu and loom and a GTR box!
But for minimum $$ pull your engine out and see what it needs to fix it or if you are in a hurry find another S1 Stagea motor.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
