R33 1998 40th anniversary.
Color: Midnight purple (MNP)
KM: 98000
Transmission: manual
I am the first Australian owner of this car, so I can tell you this car hasn't been flogged over here, also it was just my weekend drive. The car is in good condition inside and out with no tears, cuts or stains on the seats or carpet, also has the original skyline mats, the dash is also in good condition. There are only 2 bad points and I'll list those below.
Good points
-4 x brand new tyres, with about 300km on them.
-Brand new BC BR adjustable pillow top coilovers, used for about 200km.
-plazmaman pro series intercooler kit with BOV and piping.
-brand new high flow panel filter
-JL Audio 300w sub & box.
-JL Audio 700w amp
-Kenwood kvt-532dvd, flip out DVD/sterio monitor.
-engine has always been serviced on time and has no issues, (runs fine, blows no smoke)
-turbo is stock and has never been over stock boost.
-nismo 2.5/3 inch exhaust
- aftermarket front bar (has 2 real small chips from stones)
- immobiliser, alarm and turbo time have been fitted.
Bad points
- bonnet will need a respray as the paint is chipped and the clear coat is starting to fade ( I have been quoted on this so I know it's not that expansive to do so I have fixed my price to match)
- the 2 40th anniversary badges on the side of car are starting to fade as well but there isn't much you can do about that.
Car has rego till 13/5/14
Car will be sold with RWC (RWC will be done once a deposit is made, will also have the headlights restored to make them clearer for the buyer). Will also give some parts I have for the car to the buyer as well.
Price: $9500, NO SWAPS
No low ballers.
any questions or you want to see more pics pm me.
The pics were taken before I washed the car yesterday, so it looks a little dirty.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
