Thought I'd share this engine with you...
442ci General Motors based OHV V8
- no gaskets, just heat expanding O-rings
- extesive use of titanium.
- fluid dynamic crank to cut through the oil easier at speed
- turbos similar spec to what is found on Indy cars
Capable of 10000RPM (not bad for a 7.2L engine)
Early dyno run @ 25psi
1820Nm @ 7500RPM
2140hp @ 9000RPM
aiming for 2800hp with the boost set at 35psi
just the ticket for getting to work in my R32...
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/
timbar32
it says 10,000RPM not 100,000RPM. Its not a turbine....
the type racing this will be used for involves a lot of runs per meet, so it has been engineered to produce this power consistantly with needing a rebuild every run.
Basically nothing in the entire engine is off the shelf. Even the cam is considerably thicker than in the engine its based on. The write up on this suggests rather extreme levels of engineering.
7.2L, 4 turbos & 10,000RPM would sound unbelievable on the track
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-900725
nah, the guy is fairly tight lipped about many of the exact details. there is just a repeated idea that 'it costs alot to run this sort of gear'. titanium valves, springs & retainers. billet ally/GRP rods, 55mm billet cam, magnesium/thin wall stainless turbos... its insane
i guess 'alot' would be quite an understatement
RB's are nice but i wanna turbo big block!
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-900831
iv heard about this car
that thing is street legal and competed in all the street legal drags around the states, for a little while but it was banned by all of them soon after haha just too farken quick lol :)
speaking bout big hp some guy accross east, managed to get a Marlin engine (spitfire from WWII) into a car, produces 3000hp. hehe crazy bastard!
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-901001
the 27L V12 Rolls Royce Merlin was in WW2 fighters such as the Spitfire, Mustang, etc. It was also used in tanks of the era.
Rod Hadfield of the Castlemaine Rod Shop fame has spent the best part of the last couple of decades engineering a Merlin into a '55 Chev body. Apparently it quite the animal. Its appeared on TV since its been finished but I still haven't seen it.
I was 15 last time I saw that car in the museum part of CRS & it was basically just a turret, chassis & engine.
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-901067
It was on tv ages ago, can't remember what for but he was having a good talk about it . Was awesome.
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-903737
Guest INASNT
That's Mike Moran's car + motor there, he's a leading edge drag racer in the states who always seems to be driving customer's cars for them. Then he decided to build a car for himself, and look what he got :D
Yep that car has been in a special zoom magazine drag edition last year!
It was pulling low 6 second 1/4 times in that same shell last year
https://www.sau.com.au/forums/topic/44072-who-here-likes-nm/#findComment-904471
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
