Bri73y's HTA3076 is a .82a/r housing - not sure if you have seen 34GeeTeeTee's result, but they are arguably the perfect middle of the road turbo for an RB25, spool closer to a GT3071R than a normal GT3076R and make pretty huge power
Check out his result etc here: http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/
Mat's (and Bri73y's for that matter) power level in a light car should be good for 10s down the 1/4 "all in".
is there a GTX 3076 vs HTA 3076 thread anywhere??
As ive read a few on different sites... ie
"I have no proof to back my statement but I disagree. Gtx is the newest pinnacle of research from a massive company. HTA is a modified turbo from a shop which made it in advance of Garrett's current offering. Again, no proof just following logic. "
In the US and other places where people have used both (not specifically in the car) the consensus seems to be the HTA usually makes similar power but much more responsive.
Sent from my GT-I9505 using Tapatalk
Have a look around, HTA may be marginally more expensive but again if you need to get the whole bunch Bri73y might be selling a whole HTA combo which may be more convenient
If you are serious about power and response and have a little bit of budget, Have a look at our SS alpha series which is an multi stage CBB VNT turbocharger. That drives as a factory turbocharger pulling 383rwkws. This is much more then a .82 single stage 60mm turbine with a billet compressor can archive.
Of course the question is, is it heads up racing you want to do, or just chase ET's
1 thing that irks me is seeing Turbo cars sit on the line for 30 secs trying to make boost while the car in the other lane is half way down the return road
Massive +1 to all of that. "Oh hey I ran a 9 sec pass"... but it actually took 3 seconds to build boost on the brake to get that 9 sec pass and the car that runs 12s passed the line before me.
Works great for street light warriors though, you get a good 5 seconds to sit on the trans if you can read traffic lights well lol :D
A properly set-up car, won't need to worry about that. There was a VL turbo down here actually racing in S/S - That earns massive respect.
But yes, manual is going to make it had. You really need to have an anti-lag type set-up so you can build boost and leave the line with as much power as possible.
Only problem - anti lag puts quite a lot of stress on parts. Nitrous is another thing to perhaps consider, as is a great tyre/rear end setup and if possible - staged launch control
  • Like 1
Hahaa, Gotta laugh when a 16sec NA corolla is on the back road before the other car comes off the trans brake
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
