I assume you are talking internal gate housings Angelo? Most setups I have seen hold nicely near spring pressure, as you try and bleed them up it can all go to crap due to manifold pressure.
It's not such a bad thing to drop a little boost in the top end, the engine is ingesting a lot of air up there and boost is only a measure of the engines lack of airflow. Why overspin the compressor when most of the time it is just producing hotter air...
A larger turbo and or housing will always help top end flow.
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7233284
I'm running a gt3076 on a rb25 manifold with a 38mm external gate welded off it. It does not spike at all but in the top end it drops from 19psi to 16,15 psi.
I'm using a blitz sbs dual solenoid ebc.
Might need to test for a boost leak !
But if any other ideas come to mind on what it could please let me know !
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7233908
I don't think there is a housing which will cause that issue - when I had a .63 housing on mine I struggled to keep it UNDER that boost level, it was hitting 20psi by 5700rpm and trying to climb hard. The only reason the turbo itself would not be able to hold boost (assuming it's healthy) is if it is struggling to keep up with the airflow requirements of that engine at that boost level. Even a .63 GT3076R shouldn't have issues, really the compressor and turbine should be able to hold 20+psi "all in" so if it's not holding, it will be something to do with the setup - wastegate/boost controller/boost leak/exhaust leak/something...
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234226
Pressure test the intake by all means.
What spring are you using in the wastegate?
Are you using a MAC valve to hold the gate closed also?
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234355
No, you just need to sort out your boost control. Shouldn't be too difficult to work out.
Just slapping an electronic controller won't make a 4psi spring hold 30psi, you need to first match your spring to be close to your desired output, then the controller might have a fighting chance of holding what you set it at.
If that fails, you need to hold the gate shut using pressure to the top port on the gate. You would need to swap to a 4 or 5 port MAC valve to do this properly, simply cut the old solenoid out and solder the MAC in it's place.
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234623
It sounds like a boost control issue, otherwise you have all the parts to support what you want to do.
Obviously you should still check for leaks, but move to boost control if you cant find any leaks.
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234956
    • Got the gearbox in and the front drive shafts.
    • Hi There I went through a rabbit hole of reading about Xenon headlights and the ADR regulations for having them installed. As people have been defected by running factory xenon I was researching in ways to make them compliant. Everyone always say needs to be self leveling and have washer installed, which I don't necessarily agree with. For this argument I'm using R34 as reference as I'm more aware on the construction of the headlight compared to the R33 Xenon, which may still be the exact same case.   For the self leveling clause taken from ADR 13 - Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles As you can see the bold text "these manually adjustable devices from driver seats" are fine to use. As Series 1 Xenon model headlights do have a 4 level adjuster on the right near the ignition (however not series 2) then these model are consider compliant in that argument.   For the Self Cleaning aspect of this argument clause taken from ADR 13 - Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles Now i can understand the argument that Xenon will need a washer as they are over 2000 lumens, but I clicked on the 12 at the end of that sentence and it takes me to the end notes which states R34 for headlight lenses are plastic, not sure if PL is mark as I don't currently have my skyline to confirm that marking is there. But could you not technically get a lenses with the PL marking on it and then get away with the argument that you need a washer. I went through a quick read of the adr and might have missed something else that may cause them to be non-complaint.    But wouldn't these technically be complaint headlights   Would love to hear other people input on this and shed some light   Edit In regard to the the washer portion I might be mistaken ADR 45 (which I believe is Regulation NO.45) states 12 cd (candela) I dont understand that portion in regarding to calculating the candela if anyone can shed some light. Otherwise I guess throw in a washer for the headlight and you definitely comply.
    • Took it to all Japan day, flogged the hell out of it and took it all, am a very very happy man  don’t know how that ended up in Greg’s thread before
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
