I assume you are talking internal gate housings Angelo? Most setups I have seen hold nicely near spring pressure, as you try and bleed them up it can all go to crap due to manifold pressure.
It's not such a bad thing to drop a little boost in the top end, the engine is ingesting a lot of air up there and boost is only a measure of the engines lack of airflow. Why overspin the compressor when most of the time it is just producing hotter air...
A larger turbo and or housing will always help top end flow.
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7233284
I'm running a gt3076 on a rb25 manifold with a 38mm external gate welded off it. It does not spike at all but in the top end it drops from 19psi to 16,15 psi.
I'm using a blitz sbs dual solenoid ebc.
Might need to test for a boost leak !
But if any other ideas come to mind on what it could please let me know !
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7233908
I don't think there is a housing which will cause that issue - when I had a .63 housing on mine I struggled to keep it UNDER that boost level, it was hitting 20psi by 5700rpm and trying to climb hard. The only reason the turbo itself would not be able to hold boost (assuming it's healthy) is if it is struggling to keep up with the airflow requirements of that engine at that boost level. Even a .63 GT3076R shouldn't have issues, really the compressor and turbine should be able to hold 20+psi "all in" so if it's not holding, it will be something to do with the setup - wastegate/boost controller/boost leak/exhaust leak/something...
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234226
Pressure test the intake by all means.
What spring are you using in the wastegate?
Are you using a MAC valve to hold the gate closed also?
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234355
No, you just need to sort out your boost control. Shouldn't be too difficult to work out.
Just slapping an electronic controller won't make a 4psi spring hold 30psi, you need to first match your spring to be close to your desired output, then the controller might have a fighting chance of holding what you set it at.
If that fails, you need to hold the gate shut using pressure to the top port on the gate. You would need to swap to a 4 or 5 port MAC valve to do this properly, simply cut the old solenoid out and solder the MAC in it's place.
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234623
It sounds like a boost control issue, otherwise you have all the parts to support what you want to do.
Obviously you should still check for leaks, but move to boost control if you cant find any leaks.
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234956
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
