I assume you are talking internal gate housings Angelo? Most setups I have seen hold nicely near spring pressure, as you try and bleed them up it can all go to crap due to manifold pressure.
It's not such a bad thing to drop a little boost in the top end, the engine is ingesting a lot of air up there and boost is only a measure of the engines lack of airflow. Why overspin the compressor when most of the time it is just producing hotter air...
A larger turbo and or housing will always help top end flow.
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7233284
I'm running a gt3076 on a rb25 manifold with a 38mm external gate welded off it. It does not spike at all but in the top end it drops from 19psi to 16,15 psi.
I'm using a blitz sbs dual solenoid ebc.
Might need to test for a boost leak !
But if any other ideas come to mind on what it could please let me know !
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7233908
I don't think there is a housing which will cause that issue - when I had a .63 housing on mine I struggled to keep it UNDER that boost level, it was hitting 20psi by 5700rpm and trying to climb hard. The only reason the turbo itself would not be able to hold boost (assuming it's healthy) is if it is struggling to keep up with the airflow requirements of that engine at that boost level. Even a .63 GT3076R shouldn't have issues, really the compressor and turbine should be able to hold 20+psi "all in" so if it's not holding, it will be something to do with the setup - wastegate/boost controller/boost leak/exhaust leak/something...
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234226
Pressure test the intake by all means.
What spring are you using in the wastegate?
Are you using a MAC valve to hold the gate closed also?
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234355
No, you just need to sort out your boost control. Shouldn't be too difficult to work out.
Just slapping an electronic controller won't make a 4psi spring hold 30psi, you need to first match your spring to be close to your desired output, then the controller might have a fighting chance of holding what you set it at.
If that fails, you need to hold the gate shut using pressure to the top port on the gate. You would need to swap to a 4 or 5 port MAC valve to do this properly, simply cut the old solenoid out and solder the MAC in it's place.
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234623
It sounds like a boost control issue, otherwise you have all the parts to support what you want to do.
Obviously you should still check for leaks, but move to boost control if you cant find any leaks.
https://www.sau.com.au/forums/topic/440758-that-drop/#findComment-7234956
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
