Hey guys,
Was driving the GTR around the other night and just as I came on boost the hose from the turbo manifold to the intercooler came straight off. I reattached it and clamped it back on but is still running like it wasnt reconnected, I had a look at the pfc hand controller and the air flow graph was all over the place and would eventually just stall
I disconnected the AFM, started the car and it instantly stalled. I reconnected them and tried starting it again, same as before I disconnected them.
Ive had a look at the cooler piping and all seems to look okay, as much as you can see through the bumper vents.
Could there be something wrong with the AAC valve or something a bit more serious?
Going to pull the front bar off and have a better look over the weekend, but any suggestions in the meantime would be a massive help!!
Cheers
https://www.sau.com.au/forums/topic/440773-rb26-running-rough-as-guts/
An update on the situation...
I took the piping that popped off right off to see if the silicone split and there was no spliting. I shone a torch down to the intercooler inlet piping and to my misfortune there is a BUCKET TON of metal shavings.... Ohhhhh man..... Fml
I was hoping you'd say an intercooler pipe was rubbing and had worn.
one way to find out about the turbos. post a photo if you can take one. Hope your motor is okay
Im taking it down to allsparks performance later in the week to get Frank to go over it and provide me a better indication of what is going on.
Its doing similar stuff to when the first coilpack shit itself, but seeing those shaving really makes me worried. I dont know if.the previous owner had his turbos go and its just residual flakes from when they gave way and have just stuck to the blowby oil in the piping or what it is
Best case scenario, im up for some new coilpacks, worst case... You can imagine
So turns out, no blown turbo, THANK GOD! The "filings" was simply the reflection of the light reflecting off the ripples in the blowby off the silicone piping haha!!
Damien from G6 motorsport had it all day and couldn't figure out what was wrong with it.
He had a look at the spark plugs and they were disgustingly black.. Simply from when the cooler pipe popped off and the mixture in the cylinders not being what the computer was programmed for and fouled out 4 of the 6 plugs. New set of plugs and away she goes, back to normal!
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
