Hi guys.
Ive recently bought an auto 1998 stagea with a Neo rb25de and i have noticed that i have been getting around 280km to a tank, this seems pretty low even with around town driving?
I have run a diagnosis and it came back with code 55 which as i understand it means that it is all clear.
It doesnt run rough on start up or when warmed up but it does blow white smoke during high revs.
Possily a faulty o2 sensor??
Im new to the nissan game so just looking for ideas or advice.
Thanks
https://www.sau.com.au/forums/topic/440782-very-high-fuel-consumption/
That appears to be abnormally high, but might not be depending on how much fuel you put in the tank.
To be more meaningful it should be litres per hundred kilometers.
I would recommend replacing the O2 sensor on any old car as they all stop working.
Also checking the resistance of the ecu temp sensor (should be able to find that info online) or with a consult cable if you happen to have one checking what temperature the ecu thinks the engine is at when at operating temperature.
I would chuck some new plugs in it for the sake of it and check the timing is set correctly.
So it is non turbo?
So it is non turbo?
Thanks for the tips.
Its around 25L/100km i believe and yes it is non turbo.
That's way over the top. I get 12 - 15 l/100km from my RB30 turbo. You should be getting around 12.
On the other hand it is a heavy car and if you keep your foot flat like any car you can get poor mileage.
Replace the O2 sensor (don't think it will make a huge difference) and have a look at the plugs.
Jack the wheels up and make sure no brakes are binding.
Put a timing light on it (put a short lead between the coil and no 1 plug).
Make sure you are measuring the consumption properly (use the trip recorder of which there are two for some reason and calculate when you fill up again).
i thought my fuel consumption was high at ~ 13-14L/100km for a stock RS Four S turbo
i've been meaning to change O2 sensor but haven't got around to it yet . . .
Edited by Stooge007
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
