I have one of those cheap pocket oscilloscopes from eBay. Looks a bit like a toy (is actually in an mp3 player case but worked for what I needed)
Only used it to measure the dwell when I changed coils.
Also plugged it in to the cas and saw a nice signal from one wire but didn't go any further as I couldn't be bothered/didn't need to.
If I get a chance I want to take a photo of the cas signal for reference.
  • Replies 44
Gtsboy yea I seen the prices but I might be able to rent one. It does seen a little to advanced for my inexperience, the thing is my car needs to pass safety before I can pull the motor or do anything drastic. I just need the motor to run fine for the inspection. Is it the low compression in that cylinder that's causing the misfire? The engine does have a loud tick now
Bick033 ok I'm going into town tomorrow and I will get one, I couldn't really put much time into the car today as that's all I've been working on all week, and this is my last few days off work and I will be gone away for awhile so I had to do some work around the acreage. I put the plug up agains the breather and couldn't see a spark, but I will go buy the oscilloscope tomorrow and try it
You know the cam covers are isolated by rubber and won't earth the plug, earth it on one of the bolts holding down the coil bracket
100 psi won't kill a cylinder, 20 likely would
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
