Hey guys, a little dilemma...
R34GTT, Precision 5558 / 0.63 a/r, 40mm gate off housing, plumb-back 3" exhaust system, Power FC, usual support mods, stock coils, stock BOV, 100 cell Lobokka metal high flow cat, 100% street car. 286rwkw at 18-16psi by JEM with old Nistune. Changed to Power FC I picked up cheap to get retune and 'better' ecu / tunability.
Unigroup say there is a restriction in my exhaust system - the cat itself because it wouldn't make any more power going from 20psi to 23psi on 98 fuel. Power actually dropped, made a crappy 270rwkw at 20psi and very retarded timing! Recommended to change cat/ de cat with a stock shell outside etc; Current state is a very safe but very retarded tune (timing) on power FC till I get cat sorted.
Options:
http://justjap.com/index.php/engine/exhaust/catco-3-high-flow-catalytic-converter-nissan-type-3.html - highflow cat
http://justjap.com/index.php/engine/exhaust/x-force-3-stainless-high-flow-cat-nissan-type-3.html - highflow cat
http://justjap.com/index.php/engine/exhaust/jjr-stainless-racing-de-cat-pipe-nissan-r34-gt-gt-t-skyline.html - decat pipe / illegal
Please advise what to do, I already have a eGay 100 cell Loboka metal cat fitted (3" entry/exit) and that's a restriction I'm told? What is the most cost-effective way, second hand is ok.
Have read most of the cat threads, too many mixed opinions to decide, my current cat was actually bought based on these forums..
Edited by rondofj
https://www.sau.com.au/forums/topic/440825-restriction-in-the-exhaust/
Most recommended as far as my reading goes is the Venom 100cell metal 5in which I have. But you will definitely get better flow with a decat look alike if you are prepared to take the risk. I am making 314 AWKW with a GT3540 and a three inch exhaust right through. Are you sure your muffler doesn't step down to 2.5in as a lot of big brand Jap ones do? Can you get comparative flow numbers for the Loboka (never heard of it TBH) and the Venom?
Don't know the flow numbers mate, and its got two names Bokka and Loboka if you ebay it..so dodgy as, but surprisingly good build quality and the metal internals have held 2 years of hard driving. Exhaust system is 3" all the way with stock looking oval mid muffler but that is seemingly 3" as well.
Did yavus drop the exhaust on the dyno?
^^ this. How can they say the cat is a restriction without dropping the exhaust in sections?
I ran 310kw with the same cat, I don't think it would be holding you back too much, but who knows...
The difference "could" be down to the different dynos. Does your car feel slower?
Strange because Unigroup seems to have a very good reputation (although anyone can have an off day).
Maybe your second hand PFC is defective?
Did you measure the back pressure? I did a rough measure on mine by making a fitting to go in the O2 sensor hole connected to my boost gauge (not running an O2 sensor).
Lol I dont even know how to measure back pressure, and no, my PFC is sweet, as confirmed by Mark from Unigroup. He said mine was one of not many cars to be very clean with no issues apart from the bloody exhaust. And they're adamant it is the exhaust because it has so many variables and most cars they've tuned which were down on power was found to have a restrictive exhaust, notably the cat etc;
Mine was overheating and just wouldnt make power even with higher boost, power actually dropped, and according to Yavuz thats an exhaust restriction- intercoolers doin a brilliant job, confirmed..
And yes it does feel significantly slower/retarded timing from driving feel. Yavuz confirmed that timing has been retarded a fair bit by Mark.
The cat might also just be failing? Depending on how hot etc, not all CATs last forever.
I mean one brand had a LOT of failures in the latter half of last year, so anything could've happened... But you kinda do need to drop the exhaust to work that out :merli:
Hell it might even be the exhaust itself, all that gets confirmed by taking a couple bolts off - Is it a Jap one?
Ok my exhaust- custom 3' dump from back of turbo to cat, wastegate welded to turbine housing and plumbed back to dump just before cat. 100 cell gay metal cat 3' in/out and 5' body/ bokka brand. 3' pipe from cat to oval mid-muffler. 3' pipe from mid-muffler to X-force 3' straight through
oval muffler.
Gay bokka. lol.
It is a 100 cell cat with a 5 inch body, the metal cats are all much the same construction wise, there is no way it would be a restriction unless the core has shifted, which would be fairly obvious if you dropped two bolts.
I still think it's the cas, but out of interest, do you have a pic of the gate etc?
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
