Yes I do ALL of the work on my car . Amongst other things I wired up the ls coils, put the rb30 bottom end in, do all tuning and recently put some type b cams in. Not that that is particularly relevant.
You are guessing as to how much the power band will shift. Typically better cams will have more lift which will create more flow all over and therfore increase power in all parts of the Rev range, making the shift to the right not as bad as you would imagine.
Have you put in cams? Not that I care.
This is correct, a more aggressive ramp rate on the lobe will do this, depends on motor to motor though, some you can have your cake and eat it to
cheers
'darren
Well, From my understanding, the main advantage of a good ebc is the ability to "tune" the ebc to make the boost do what you want, i.e hold flat to redline, and how it ramps onto boost.
If your looking to get everything you can out of your setup I'd think it would be an advantage.
But back to your original post, are you unhappy with how the car goes? or do you just want it to make a number? cause the power figures your talking about, I dont see much variance in them, and they're also over two different tuners and two different dyno's.
Plus your saying the car feels better now, so whats the issue?
More boost will make a restricted system worse, if the rear housing or manifold is restricting the system more boost will dramatically increase manifold/back pressure coursing detonation
Get an EBC, they are better all round and will hold the wastegate shut longer by not allowing it to creep open which will make it ramp onto boost quicker and you can try different boost levels to better see what's going on
We tried 22psi on my 32 but didn't gain any more power but had to remove timing, 19psi is the sweet spot for my setup, you need to find yours
Same thing with my 34, we couldn't run more then 28psi for the same reason, the twin .64 on a 3ltr don't like that much flow
I'm already at the limit of my boost level of 22psi on 98 fuel so not looking for more boost. But that boost is dropping down to a max of 4psi after 4500rpms onwards, so am looking to hold it up as far as possible and bring it on harder/make a few more kws and quicker car.
I never really understood the point of installing a turbo that is suppose to be efficient at higher pressure ratios, then jamming into restrictive housings and stock exhaust manifolds. On 98ron its the perfect combination for a mediocre result....
Sounds like the setup is much better suited to a hypergear turbo.
Just my 2c
rondofj- at the risk of stating the obvious, are you still using a 0.63? maybe I missed something but if so then isn't that the limit of the housing? I must of missed something lol.. flame on!! haha
Yeh mate, 0.63 like Kurtis did on his neo- 372kw from that on e85 and high mount mani. If you take 15% off that to get a rough estimate on 98 you get 316kw which is roundabouts what I should be making yeah? 316kw and 280kw is a big difference, even if mine is low mount
Yep you can't just say should be around 316kw
There are a lot of variable between yours and his setup
Yours is on the std manifold his has a high mount tubular manifold
Was his tuned on the same dyno as you I don't think so
His can handle more boost than your cause the e85
Engine cond can't be the same
Intake will less restrictive on his as it's highmount less bend and so on
There's your 20-30kw differences there
Either way your are very close to the limits of the .63 rear housing and your engine will be a lot happier with a .82 rear especially on pump 98
Yes it will be alil Doughier maybe 2-300rpm laggier but it's worth the piece of mind especially on pump 98 and at those boost and power levels
You can't have the best of both worlds or deal with it being restricted and less power but more responsive
Whether its a $100 exhaust or a $2000 branded shiny one, flow is all that matters and mines sorted flow wise so that makes no sense. Stock mani 'could be a possible restriction. 0.63 housing- Im not sure how different this is to the garrett version. And 15% less kw on 98 than e85 'generally goin by info on many forums.. In either case i should theoretically be at least over 300..
Stop being a dyno queen dude and just be happy. You came here because of a restriction, you got that sorted and you said the car was driving better than ever. So why is this still going chasing the 300 that you believe you have been robbed?
People have already told you the variables and the biggest one is the dyno. It gets said time and time again that you can't compare results on different dynos. So either go chuck your car on their dyno or just be happy that your car is in the range of what's expected
whats the difference between a garrett 0.63 and a precision 0.63? if there isn't much then 280 is going well, if the restriction in exhaust is solved then surely the housing is the next thing to change.
In your first post you state you lost power going from 20 to 23 psi and you made 270kw at 20psi with very retarded timing, so if you lost power going from 20 to 23psi then I wonder if you lost power going from 18 to 20psi and having to retard the timing at 20psi
Get it back to 18psi and see if that allows them to run more timing and see if it gains you any more power
E85 benifits knock limited engine a lot more then ones that aren't, there certainly isn't a rule of thumb on gains from converting to E85, some motors might pick 5% where other may gain 40% really depends on how the motor is setup and if its limited by knock, I'd say your motor will pick up a heap from going E85 cause it sounds like it is very knock restricted
  • Like 1
I found a VW forum where a guy has a few similarities to your setup, he mentions that the seimens fuel injectors are a bit unreliable, he is using 35psi and only getting 420ish hp and high reading dyno,
maybe your turbo is just at its limits and the fuel injectors are shithouse, if they partially sieze up or the spray was rubbish, that might be restricting the tune. This guys AFR is up and down.
http://forums.vwvortex.com/showthread.php?6149918-5558-Dyno-Results-and-what-I-ve-learned&p=83227622#post83227622
I vote for 0.82 rear and some 1000cc ID's
Edited by AngryRB
  • Like 2
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
