More boost will make a restricted system worse, if the rear housing or manifold is restricting the system more boost will dramatically increase manifold/back pressure coursing detonation
Get an EBC, they are better all round and will hold the wastegate shut longer by not allowing it to creep open which will make it ramp onto boost quicker and you can try different boost levels to better see what's going on
My thoughts too. If nothing else the tuner can TRY and hold a steady boost level to redline - if they try and hold 20psi and they run into flow issues or holding boost issues they SHOULD be able to build a bit of a picture of which area of the setup is starting to hold things back.
My feeling at this stage that you may be getting near the limit of this kind of combo and are probably already making decent power - though the bleed valve could be exasperating this. As I asked in PM, what discussions have you had with your tuner about it? They will have more of a perspective than any of us on how the setup is behaving... we're just taking pot shots from what you have shared.
My tuner said that at 23psi it wasn't making any more power so they backed it off to 22psi on a safe but still optimal tune, recommended Type A Poncams for more power and an EBC to hold boost steady up top. EBC I will get, cams not, they didn't mention anything about exhaust manifold being restrictive or housing. Yavuz did say that with a bigger housing I could get more power but that's only after I asked, so not really recommended me one unless I really wanted to go that way. He said these Precisions will easily boost to 30psi with e85 and the right setup.
Edited by rondofj
OK - the fact he recommended an EBC is a huge hint, if it's not holding the boost he wants and it's making respectable power for the boost it is running at peak power then that is a pretty big indicator I reckon. Holding more boost at higher rpm = holding more torque at higher rpm = more power :)
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
