Mick how does your system go for noise suppression?
It would have plenty of flow capacity, be good to see pics for how it looks and fits.
It's a lot quieter then the 80mm jap exhaust I took off, it's not that loud until you get on the loud pedal then it gets up there, but idleing it has a nice tough murmur, Paul heard it tonight maybe he can comment on it
I have GT-RSs on the car so I needed as much flow as I could fit under the car
How about this , where your oxygen probe goes get a plug and drill/tap/braze whatever a take off into it and measure the pressure in the exhaust behind the turbocharger .
Compare it to boost pressure and note the difference .
It may not be a bad idea to pull the cat out and see if its blocked or collapsed as well . Changing that mid muffler shouldn't be a biggie surely .
A .
Couldn't hear it. All I heard what that farken pump. BBBBBZZZZZZZZZZZZZZZBBBZZZBBZBZZZZZBZBBZBZZZZZX
  • Like 1
That's not really the ratio you're supposed to look at against boost pressure though. Ex manifold pressure against boost - yeah, fine. But not really dump pressure. Realistically, if you have more than a couple of psi of back pressure in the exhaust you're looking at a substantial restriction. So measuring the pressure there is a fine idea, but you're really just looking for the absolute amount of backpressure.
It would also pay to measure after the cat too, just to see if the cat is the problem or if the mid muffler is the problem.
But, my 2c on that issue is (which coincides with a lot of opinions above)
1) Why not just drop the exhaust behind the dump and take it for a quick drive, see if it changes behaviour?
2) Unless there is a massive step down in the muffler(s) it should still handle quite a bit of gas flow without killing the power. So you have to wonder about tthe cat more than any other part.
Well this thread is about exhaust restriction and anything significantly positive behind the turbocharger under load tells a story . I just picked on the sensor location because it's an easy place to tap from . If that exhaust is restrictive and gets fixed the dump pressure should fall and so should the exhaust manifold pressure . Boost and power characteristics should change as well .
A .
What do you guys think of this - ok or a pile of junk? The cat is a gutted catco item (what I was suggested with a bit of reluctance), the mid-muffler looks 3" in/out (no necking like mine), the rear muffler is a crappy jasma cannon but free-flow from the look of things.
System is off a 33GTST goin for cheap ( I know 34 is slightly shorter) and the I'm thinkin of buying it..
Edited by rondofj
Doesn't seem too bad for $100
Has a gutted cat already and a 3inch in and out same side mid muffler so that shouldn't be a problem
Just sack that rear cannon as most jasma approved mufflers have a smaller inner pipe which the oval muffler should fix
Worth it for $100 imagine how much it will be for a new custom 3inch catback atleast $500
The step down pipe is rarely in the mid muffler
Is almost always in the rear muffler or cannon
If the mid muffler is stepped down it's usually on the inlet or outlet and not internal as that muffler isn't offset so will be straight pipe thru just perforated and packing around it
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
