A guy with PT5558 on R34 neo made 372rwkw @26psi, the only difference- he had e85, top mount ex manifold and ffp. Mick O made 335kw on stock manifold btw...
In this case the OP6 high flow made more power on less boobst :P
Like mentioned earlier, higher octane fuel will allow you to run timing that is closer to the optimum degree.
Or you can also enlarge the exhaust side turbine wheel that has similar effect to an larger rear housing. This case a larger housing would be the cheaper way to get more power.
What I was tryin to say is I dont think the turbo is a limitation itself since 372kw and 360kw was made with the same turbo on a neo and an sr (both e85) respectively, as posted by the guy above. And mick O did 335kw on stock mani, so have many others gone over 300 on stock mani. Just my opinion
Well SR20det in .63 is equivalent to an RB on something like a .84. That R34 has much better hot side setup then yours and on E85.
Like mentioned earlier, Tuning P98 with a tinny rear housing will need to have detonation in mind, in which you will have to back off timing from the optimum ignition angle to avoid pinning. You have less of this issue tuning E85 fuel, that allows you to fire spark closer or at the crank angle for optimum engine output.
Or you can just run E85, which should boost up 40KWs in power getting you over the 300rwkws mark on the same boost level.
Edit:
Add in one more piece of information: Garrett GT30's turbine is in 60in / 55ex. The tip height and exducer area determines the total capacity of discharging, so technically this turbine does not have much better capacity to a GT30 turbine.
How much more power do you think a 0.82 housing will give me? 10kw? Not worth the removal/fabrication of gate/ labor again I think.
Yavuz suggested cams and also an ebc to keep boost up. Any guesses as to how much I will gain with an ebc holding boost well. 280rwkw was made on 18psi not 22.
If it was CAS, a tuner like Yavuz or even Mark should have been able to pick it up straight away and inform me? Or tested a different one. Well changing the exhaust definitely did feel a noticeable gain on the road from driving feel (without touch up tune), after the touch up tune it felt a lot lighter and torqueyer down low, so definitely the exhaust had some restriction. One strange thing now 100km/h in 5th is @2600rpms, before exhaust/touch up tune 100km/h was at 3000rpms...
Cams in a rb as tested by Tao only gain very little but shift power band higher
Where as you where making 200kw by 4000rpm it will proberly be 150kw and full boost will be later as well so won't be good for street and be felt at the track only
You should have ran your nistune tuned by Jem with 287kw on Unigroup dyno and seen where it was at to compare but does it feel quicker than before or the same ?
You can't establish anything from that test, as it lost vct. And you are guessing wildly.
There are results of cams picking up power everywhere, for example Matt from Nistune's r34.
It doesn't feel quicker, much less the same, maybe pulls a wee bit harder in 3rd/4th and a lot better under 3000rpms - more light/torquey down low, this is the area that wasn't tuned well with Nistune. Also cold starts and idle is much smoother and like factory now, before was rough and I had to crank twice/push gas pedal to start.
That's a shame that your Nistune wasn't tuned correctly. Don't blame the ecu.
It would have to be the easiest ecu to get cold start and idling nice with.
That makes no sense.
Diff ratio is the same. Revs the same.
More revs needed before for same power/speed looks like it? Remember its a freer exhaust now, so boosts quicker and makes more power at least 400rpms earlier. And more timing been added across the rpm scale. And yeh they didn't tune the Nistune correctly, not even after the second time.
That doesn't make any sense. If you had 1000hp it should still sit on the same rpm at 100km/h.
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
