This isn't another which coilover should I buy thread.
I bought my 25GT with Tein coilovers on it, but I'm not sure what sort of Tein Coilovers, as I haven't had the wheels off yet for a closer look.
As usual they're really rough when I drive over any kind of imperfect surface, be it a speed bump (the narrow kind they put in shopping centre car parks to destroy suspension because who speeds in a car park) or a very minor change in road surface where bitumen has been relaid. I do know they're damper adjustable, but don't really know which way to turn the knob thing to make them softer. Can someone explain this to me?
Also the front driver's side makes a noise when going over any of the aforementioned surfaces, like fluid passing through the damper and the rear passenger's side squeaks when travelling over bumps too quickly for the suspension. Is there a way I can find out if I need to replace the dampers or springs on the coilovers?
With regards to my brakes, when I bought the car I was told the front pads would have to be changed, and then told that they were done as part of the roadworthy after I arranged for one. I suspect the brakes may not have been bedded properly, as they creek when I brake with low-medium effort. Is it possible to bed brake pads without knowing what sort of pads are in there, should I just keep driving my car and ignore the noise, hoping that the pads bed in, or do I need to take action and see a brakes and suspension specialist?
https://www.sau.com.au/forums/topic/440848-coilover-and-brake-qs/
Not sure about Teins specifically, but the adjustable dampers I've used have all been clockwise to increase damping effort (except some Konis that you had to compress, then turn the whole body - can't recall which way they went)
The dampers should be matched to the springs, so if you back them off too much, they might become bouncy. Better to overdamp a spring than underdamp - it might be that the springs are too stiff too (this is a Japanese thing where their tracks are like billiard tables and you can get away with very high rate springs).
Squeaking in the damper could be a seal rubbing on the shaft - some Inox or WD might clear it up, but this is often a sign of a drying seal that might be needing replacement soon.
Check the pads to see if they've been replaced. You should be able to see them with the wheel off (should have around 10-12mm of meat on the pad, maybe more if they're new). Again, brake pads can make various noises, so some are more normal than others. Bedding in brakes isn't as critical as it used to be - manufacturers often sinter the pads on a hot plate as part of the manufacturing process, so they should be fairly good out og the box. Of course bedding in will nearly always improve them, so can't hurt.
The basics of bedding brakes is the same for nearly all compounds. Heat them up repeatedly through moderate braking effort (say braking from 80 to 20), allowing about a minute to cool down between runs (but not coming to a complete stop if you can avoid it). You can increase the braking effort after you've done a handful of these, to the point that the pads might start to smoke (but don't apply full brakes at all - maybe only go to 60-70% braking). Smoke / burning isn't a problem, as it's just burning off resins etc. left over from the manufacturing process.
Once you've done this, let the brakes cool (preferably whilst still driving) and they should be good to go.
Whether bedding the brakes makes any difference is anyone's guess, without knowing what was done, and what the problem actually is.
Anything beyond the above, and you should take it to a reputable suspension and / or brake specialist. Not worth stuffing around with these things if you aren't confident.
Edited by warps
Does increasing damping effort make the ride smoother or rougher? Sorry for nooby questions, I really don't know much about cars, lol.
Main problem is most likely the spring rate so damper adjustment won't help.
Generally, leads to harsher ride, but matched dampers to spring is better than having choppy suspension (over or under dampened).
What he said.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
