2X Mines Air Flow Meters for sale...
Upgraded to a Power FC computer and went to a pair of Z32 AFM at the same time.
The MINES AFM are just sitting around so i would like to sell them!
I have been told the Mines AFM have similar resolution to the Z32 AFM while still adapting to the standard air box or aftermarket 65mm inlet/filter pipes.
EPROM or re-tune of computer will be needed in conjunction with these as they are not the same as standard.
AFM: $400 for the pair, will not seperate.
I can also sell the BNR32 GTR ECU that was tuned to run the following:
-Mines AFM
-HKS 600cc Inj
-Trust 264 9.1mm Camshaft
-Tomei adjustable cam wheels
-HKS CDI ignition
ECU: $300 (reduced), will seperate from MINES AFM
TG
Penfold,
yes theoretically i could have gone that option. I simply got a good deal on a brand new set of Z32 AFM that are 80mm compared to the 65mm standard size MINES AFM and wanted more air flow from the larger sized units.
The reason the MINES AFM were used on my original setup were so that they could be hooked up to the HKS suction and pipe kit installed on the car, while being able to be tuned with more resolution than the original units.
The actual back to back performance and tunability of the MINES AFM vs. STANDARD AFM i am unsure of. Perhaps a thread in one of the forums in this website can answer this for you.
In terms of MINES AFM vs. Z32 AFM, obviously the Z32 AFM will out flow the MINES unit, which is my basis for the upgrade.
The MINES AFM would suit someone who would like to run their original piping kit and slightly re-tune their ECU to suit.
Did that answer your question?
TG
yeah still available...
actual mines AFM km's unknown but the car has done 60,000 km's... I assume the modification was done around 35-40,000 so id expect them to have seen 20-25,000 km's.
They are in very good condition. Also includes adaptors from the front and all silicone hoses for an HKS filter and pipe kit.
For pictures, goto my for sale section in the private for sale cars section and search for midori bnr32 for sale
TG
