Hey peeps,
Im doing a r33 turbo install on my NICS Rb20det soon.
As im sure you know the NICS ECU does not handle fueling too well and almost nobody can EPROM them so....
I will be needing some form of tuning mod, so i was wondering if you think i should go the SAFC and EBC route or go for a Wolf3d V4?
Costing of the components looks to be about the same but obviously the actual wolf install is going to cost a bit more.
any comments/recommendations/opinions would be appreciated
also any suggestions on who to get to do the install of both turbo and wolf?
cheers
https://www.sau.com.au/forums/topic/44090-safc-and-ebc-or-wolf3d/
  • Replies 63
i went the way of ebc and afc....over the wolf because i saved money on installation (myself) and got some stuff second hand....
tuning a wolf is more expensive aswell im sure....and with the boost control of a wolf i heard you cant control how the boost comes on like other boost controllers can.
does anyone have any experience with wolf controlling boost?
Yep, I have a Wolf.
I would recommend the Wolf, it allows fully control and customisation of the fuel, air, ignition, boost settings.
It also takes about 10 mins to install. Which ever way you go the car will need tuning (dyno time) and the Wolf is easy to tune.
I asked many about this and told a full ecu replacement is the way to go.
Go the Wolf!
Just getting used to mine but all good so far.
Goto www.wolfems.com.au & download V4 User Guide , it shows Boost control every 125rpm from 0 - 16000rpm! With boost cut options. :)
The other main advantage over SAFC/EBC is ignition control!
Oh yeah....& flick the "NICS" lol
With the Wolf Boost control I can only find a Valve Setting, which increases the boost depending on the value value. Is there another setting to set the actual Boost (PSI) for each 125rpm??
The boost cut is in PSI but then again it only drops it back to a Boost Valve setting
Just means you need to test it out with a few trips up and down the road.
only thing that worries me is that lots of the cars that have got wolfs have blown up....
Its all to do with the tunning, if the tunning is right then your not gonna blow your engine up. Its the same with any programable management system not just wolf. I have had 3 wolfs, version 3 and version 4 on my old rb20 and now version 4 plug in on my rb25 and never had any troubles.
if they were all the same price and installation costs the same what would you choose paul?
microtech, wolf, autronics or haltech?
nothing against the wolf but everyone didnt think anything of wolf until Ant started hitting big figures with his wolf....
im not trying to say im an expert but wolf ecu seem to be in the more less hardcore category of ecus, if you want serious power on any project i have seen no one has chosen a wolf.....why is this?
yeh i am thinking the wolf is looking the better option, however am i better to spen the money on a 32 rb20det install?
This would be great but requires me to run a whole new loom for it :)
Plus rip out the current motor (which is running fine atm)
So...im thinking ill stick with the NICS (i know its not the best engine ever made) and run the RB25 turbo, go the wolf install and see what i get from the tune.
SST the go for the wolf install/tune? What sorta $$$ would i be looking at?
ta
Its worth considering wolf v4 doesnt have sequencial injection. Where as your powerfc, autronics and microtech ltx12 does. Of the modified rb25s that have blown up this year so far, which ones have had wolf? Im sure the mortality rate of rb25s in the eastern states is not as bad.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
