Hey peeps,
Im doing a r33 turbo install on my NICS Rb20det soon.
As im sure you know the NICS ECU does not handle fueling too well and almost nobody can EPROM them so....
I will be needing some form of tuning mod, so i was wondering if you think i should go the SAFC and EBC route or go for a Wolf3d V4?
Costing of the components looks to be about the same but obviously the actual wolf install is going to cost a bit more.
any comments/recommendations/opinions would be appreciated
also any suggestions on who to get to do the install of both turbo and wolf?
cheers
https://www.sau.com.au/forums/topic/44090-safc-and-ebc-or-wolf3d/
  • Replies 63
i went the way of ebc and afc....over the wolf because i saved money on installation (myself) and got some stuff second hand....
tuning a wolf is more expensive aswell im sure....and with the boost control of a wolf i heard you cant control how the boost comes on like other boost controllers can.
does anyone have any experience with wolf controlling boost?
Yep, I have a Wolf.
I would recommend the Wolf, it allows fully control and customisation of the fuel, air, ignition, boost settings.
It also takes about 10 mins to install. Which ever way you go the car will need tuning (dyno time) and the Wolf is easy to tune.
I asked many about this and told a full ecu replacement is the way to go.
Go the Wolf!
Just getting used to mine but all good so far.
Goto www.wolfems.com.au & download V4 User Guide , it shows Boost control every 125rpm from 0 - 16000rpm! With boost cut options. :)
The other main advantage over SAFC/EBC is ignition control!
Oh yeah....& flick the "NICS" lol
With the Wolf Boost control I can only find a Valve Setting, which increases the boost depending on the value value. Is there another setting to set the actual Boost (PSI) for each 125rpm??
The boost cut is in PSI but then again it only drops it back to a Boost Valve setting
Just means you need to test it out with a few trips up and down the road.
  fane said:
only thing that worries me is that lots of the cars that have got wolfs have blown up....
Its all to do with the tunning, if the tunning is right then your not gonna blow your engine up. Its the same with any programable management system not just wolf. I have had 3 wolfs, version 3 and version 4 on my old rb20 and now version 4 plug in on my rb25 and never had any troubles.
if they were all the same price and installation costs the same what would you choose paul?
microtech, wolf, autronics or haltech?
nothing against the wolf but everyone didnt think anything of wolf until Ant started hitting big figures with his wolf....
im not trying to say im an expert but wolf ecu seem to be in the more less hardcore category of ecus, if you want serious power on any project i have seen no one has chosen a wolf.....why is this?
yeh i am thinking the wolf is looking the better option, however am i better to spen the money on a 32 rb20det install?
This would be great but requires me to run a whole new loom for it :)
Plus rip out the current motor (which is running fine atm)
So...im thinking ill stick with the NICS (i know its not the best engine ever made) and run the RB25 turbo, go the wolf install and see what i get from the tune.
SST the go for the wolf install/tune? What sorta $$$ would i be looking at?
ta
Its worth considering wolf v4 doesnt have sequencial injection. Where as your powerfc, autronics and microtech ltx12 does. Of the modified rb25s that have blown up this year so far, which ones have had wolf? Im sure the mortality rate of rb25s in the eastern states is not as bad.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
