  • Replies 63
Autronic you say? Yeah, great support there.
MoTec or at least Power FC please.
I've heard too many horror stories with Wolf now that I am scared. Honestly the amount of RB25's i've heard blowing up with Wolf's alone far exceeds a total of all others. However, the ones that have all gone to my knowledge have been stock injectors pushed too far with pressure regulators etc.
Josh
go a unichip (if they work on ur car that is)
Cheaper then a safc and ebc combo, and unichip controls both ign and fuel, and has a boost controller aswell, like the one i have for sale. Check it out. Id recommend it definately over safc, but if u want to spend more go a full ecu like the wolf.
goodluck
Fane, Can you name any RB25 with forged pistons that has blown up on the Wolf?
I can name a few forged piston engines which have blown up with both PowerFC's and Autronic's on. What does this tell you? Nothing. Engines have there limits, and not all tuners are equal.
WE see as many blowen 25s with PFC and factory ECUs.
Use what ever you want im not bothered but dont expect to beat our guys as Ant and Fabs are moveing the bench mark much higher.
Even GTAAH picked up 70rwhp by replacing his big name ECU with a wolf and The CRED R33 GTS ran well at 400rwhp on a stock RB25 at the drift last weekend. The bigggest drawback with Wolf we cant get enough units to keep up with demand.
You say the old wolf was outdated but forget the old Motecs were screw driver tunable so dont judge the latest units by old models but then again there is some very tough cars out there with V3s.
Basically the long and the short of it is that as long as the tuner is comfortable with the ECU and knows its limitations then there shouldn't be any problems... Every ECU has hidden tid bits that perform certain functions... The other thing to remember with tunable ECU's is that if the customer plays with the settings then its not the tuners or ECUs fault for lunching the engine... But sometimes freak things DO happen and its NO ONES fault...
fane,
to say that because rb25s with wolfs have got belly-up may be true - but I think that you're drawing a long bow to say that the two are a cause and effect.
there is a very good looking morone r32 gtr which spun a bearing some time ago. in a really sad story, it has been rebuilt, was running a pfc, nismo turbos, great fuel pump, and it recently spun the same big end bearing in tune. so what can we infer from this? that the rb26 is a shit engine? (no!) that the skyline is a bad car? (no!) that the power fc is a crap ECU? (nope!).
the simple fact is that mechanical failure is not always a result of the ECU, or the car, or the engine - and so on.
as far as this relates to ECU's, and your questions, the skylines which have shat themselves recently have sometimes had wolfs in. however, they are now more powerful than they were before, are subject to greater loads - often using higher boost and turbos. as paul pointed out, the incidence of ringland failure is more symptomatic of the capacity for the ringlands to sustain 350rwhp than the capacity of the ECU to hold a good, safe tune. notwithstaning this - it may be worth asking what other support upgrades had been included? how many of these cars had baffled surge tanks, oil coolers or improved radiators? how many had headgaskets (debate unto itself) or forged pistons?
the first reality is that the ECU is only as good as the tuner. we're lucky to have someone in WA who is adept at tuning the wolf - and so that's what a lot of people are using. the second is that the engine is only as good as the engine. and a ten year old rb25det is only good for about 300 rwhp reliably and any more will be pushing it.
that's not to say the wolf is categorically the best ECU around, either. it can be argued that the processors on wolf arent as good as some other ecus. just do a search. however, given that we are talking about what are generally street cars, the wolf provides more than enough capacity to provide a good ECU, and has options easily at hand that are not available or not included in the base price of other ecus.
as far as AFC + EBC or full ECU, I cant figure why you would buy two seperate items - that cant talk to each other directly other than via the factory ecu and the engine - when you could have a single unit, and save yourself the spaghetti bullshit for around the same price.
One of the best knowen Blowups in WA was an RB26 with a cost no option build running a Jap remap and tuned but a well knowen jap tuner and the car was making over 100rwhp less than ND4SPD and GTAAH so whats the point in blaming Wolf ECUs? When PPL want to push for high power from stock parts things will fail.
i understand the limits of the rb25/26 and pushing them is usually the reason for them to go keeerrrpow!... and i wasnt blaming wolfs for the deaths either...i was just interested about why the wolf is only so huge in WA.
my guess is that its because we have tuner here that can tune them and no one else really can crazily tune anything else....and with cars like ND4SPD promoting the wolf its hard to say a bad word about them....because 500 ppl come on here and stick up for them because they probably have one :rofl:
merely posing questions not pointing fingers....
Well i just bought a Power Fc, and had of been able to find a tuner in Melb that had installed and tuned one on a car similar to mine which had ran reliably for 6 months, then i would have happily paid the money for the Wolf.
I didnt really want a Pfc, but dont have the garage space or time at the moment to install the Autronic, making a plug in ECU the only choice... Wolf or Power Fc, the Wolf would have even been cheaper.
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
